Old 04-14-2009, 06:07 PM   #1
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Project "Vertically Challenged"
Getting closer every day! I suppose it will be setting on it's wheels tonight? I've got a window regulator to put in,... I'll check back later for an update.
Not tonight. It's supposed to rain all day tomorrow. I'll lock myself in the garage then.
Originally Posted by VA72C10 View Post
Looking good...left you a voicemail about a blazer I'm looking at
It's to cloudy for my cell. No reception. Shoot a PM, what did you find, details please
70k52wd is offline   Reply With Quote
Old 04-17-2009, 10:21 PM   #2
70k52wd
Blaze-Air
70k52wd's Avatar
My to do list is...Bleed brakes, install shocks, get it off jacks. Then wire AirPod up. Done. I think...Then, exhaust, rebuild carb, and alignment, remove top and drive....The first part tomorrow, second part hopefully within the next week or so.
You can see my front airlines running down the bottom edge of the frame. I am so paranoid of heat I wanted it far away from any source. It's both lines running into heater hose, then spark plug heat sleeve over heater hose. Ugly yes. Melt proof definitely. 20's will hide it....I should have a pic of it tomorrow, we'll see what happens.
