Old 04-14-2009, 08:28 PM   #1
VOLZ1207
another lowering question....will this work?
hello. i have a 72 lwb lowered 3 1/2" front 2 1/2" spindle and 1" lowered coil, and i have 3" springs and 2" blocks in rear trailing arm setup. can i go to a 3" block for a total of 6" drop? i know that i probably need rear shock relocation kit as well. i have not measured the pinion angle as of yet, but i have not noticed any problems with my current setup. at being lowered 6" will i put the driveline in a bind or is every truck different? has anyone ran this setup?
VOLZ1207 is offline   Reply With Quote
Old 04-14-2009, 08:31 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: another lowering question....will this work?
My truck is lowered 3.5" front and 6" in the back. Haven't had any pinion angle problems as of yet.....Been driving the heck out of it for several years now as well.
see ten is offline   Reply With Quote
Old 04-14-2009, 08:43 PM   #3
VOLZ1207
okay, i was just checking to see if i can do the combination of 3" springs and 3" blocks. do you have the rear shock relocation brackets? thanks for the info
Old 04-14-2009, 09:32 PM   #4
see ten
WTB this ad
see ten's Avatar
Yes we relocated the shocks. I can't help you much with the blocks...I've never used any.
Old 04-14-2009, 10:40 PM   #5
nicks05z71
nicks05z71's Avatar
It would work, but...with a 3'' block your scrub line will be really low...lets say you have 15'' rims. Your driving down the road when you get a flat rear tire, the first thing to hit the ground would be the bottoms of your u-bolts/shock relocators, creating a dangerous situation.
nicks05z71 is offline   Reply With Quote
