Old 04-15-2009, 08:53 AM   #1
JimmyFloyd
Blazer frame vs Shortbed Frame
Are there any differences between the Shortbed frames and the blazer frames?
i have a chance to pick up a shortbed in ok shape and running, and was wondering if I could swap my tub onto it while I finished up my frame and suspension.
JimmyFloyd is offline   Reply With Quote
Old 04-15-2009, 09:04 AM   #2
71swb4x4
71swb4x4's Avatar
Re: Blazer frame vs Shortbed Frame
The frames are different. The short bed frame is longer. It also is not set up for the tub mounts.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-15-2009, 09:42 AM   #3
70 Suburban
Rods
truck frames are also wider from the cab back. the spring and shock mounts are not in the same location.
70 Suburban is offline   Reply With Quote
Old 04-15-2009, 07:50 PM   #4
brian26
I shortened a 72 suburban frame down to 104" without any issues.
brian26 is offline   Reply With Quote
Old 04-15-2009, 08:09 PM   #5
70 Suburban
Rods
ok thats nice, but thats not what he asked. he asked what the diff is. and i told him. if your not sure still. them I will be happy to use a measuring tape and show you. I have a gm 12 bolt from my doner truck its spring mounting pads are about 3 in off on each side. the frame width on a truck is wider than a blazer. Did you also use the blazer suspension under it... did you have a lift kit. If you did. did you spread the leaf springs out... hmmm I think not. Im thinking u used the suburban suspension.
Old 04-15-2009, 08:16 PM   #6
brian26
There is trailing arm suspension, and leaf spring suspension. On all Chevies under 1ton, they had trailing arms as standard when it comes to 2wd, leaf for 4 wd.
Leafs were optional for 2wd. GMC had leafs as standard equipment.
Been at these trucks for a while pup, no need to act like a smartass.
Old 04-15-2009, 08:21 PM   #7
brian26
I have 3, THAT'S THREE, BLAZERS OUTSIDE RIGHT NOW THAT I HAD TO WORK FOR.
1 has a shortbed frame shortened down to 104", the other has a Suburban frame down to 104", same suspension bub, I have paid my dues.
Old 04-15-2009, 08:37 PM   #8
big mike71
big mike71's Avatar
You didn't pay tour dues to the site,and before you say it my checks in the mail.
big mike71 is offline   Reply With Quote
Old 04-15-2009, 08:47 PM   #9
brian26
http://s201.photobucket.com/albums/a...SANY2427-3.jpg
Old 04-15-2009, 08:49 PM   #10
brian26
The blue one with black hood was built bolt by bolt from the ground up by me. Especially the top.
2wd shortbed frame and drivetrain underneath. Yes it is a good idea to make some body mounts from the frame to the tub just behind the doors, just like the regular blazer frame has.
The next time I do it over, the frame is getting boxed to cut down on body flex, the movement at the top of the doors when the top is off.
Old 04-15-2009, 09:24 PM   #11
Jtrux
I'm a poor spectator
Jtrux's Avatar
70 suburban, I hate to say it but you're both out of line, and wrong.
A shortbed frame or blazer frame as long as both are 4x4 don't have different widths or at least the axles will bolt up between the two.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-15-2009, 10:37 PM   #12
70 Suburban
Rods
you would have to prove this to me. I just went into this same problem when I blew the rear out of my blazer. I tried to take there rear out of my gmc... no go then said well leme see if I can take it from the 4wd short bed..... no go. sprng saddles were to wide.
Old 04-15-2009, 11:00 PM   #13
brian26
Well, do you have a 2wd Blazer or a 4wd?
Old 04-16-2009, 05:36 AM   #14
vtblazer
vtblazer's Avatar
What's the story here?
vtblazer is offline   Reply With Quote
Old 04-16-2009, 08:06 AM   #15
brian26
Thanks for getting that up for me. I have had hard time posting pictures here and I just cannot get them on here for some reason. I have no problems everywhere else, but here.
Old 04-16-2009, 08:09 AM   #16
brian26
It's imperfect, but it works. Steel retractable top, there are a few other shots on this site about it.
Old 04-16-2009, 08:13 AM   #17
70 Suburban
Rods
Brian did an amazing job on this... BTW hi is not an engineer. I have talked to him about this b-4 lots of hard work and man hours to make it happen.
Old 04-16-2009, 08:59 AM   #18
brian26
Thanks man. Sorry for responding like I did.
I got off into old race cars and right now it's difficult to find the time to get back on this project. It took so much of my time for years. Started when I was 26, got it out when I was 35.
I keep thinking, 'aircraft aluminum and fiberglass'. I had to go all steel here since that is the only thing I am able to weld.
Old 04-16-2009, 09:02 AM   #19
brian26
This link might give some more pics
http://s201.photobucket.com/albums/a...2-2007-083.jpg
http://s201.photobucket.com/albums/a...t=SANY2597.jpg
Old 04-16-2009, 09:13 AM   #20
70 Suburban
Rods
IM NOT SURE WHERE YOUR LOCATED BUT MAYBE i CAN HELP YOU. iM GOING TO MAKE A FIBERGLASS HALF TOP.. MAYBE ILL MAKE TWO
Old 04-16-2009, 09:16 AM   #21
brian26
I would post some more detailed pics of the working underneath, but the whole issue of "public domain" bothers me a bit. I have had others tell me I should patent it. Yet, I have talked with those that have had patents and in the long run, patents are really weak and for the most part, benefit the paper industry. You know, red tape, involves paperwork and uses up their product.
Old 04-16-2009, 09:17 AM   #22
JimmyFloyd
They were getting URL tags, instead of Image Tags. And you are copying the webpage rather than the picture location (right click, copy image location in Firefox)
Old 04-16-2009, 09:18 AM   #23
brian26
Are you outside of Boyd?
Old 04-16-2009, 09:19 AM   #24
70 Suburban
Rods
Well there is a loop hole... The trick is to take pics. Make blueprints and story the operation. Then send it throug the mail to yourself. Dont open it and you will have documintation that its your idea.. Do a couple of them so if you wind up in court you will have an un opend document stamped by the federal gov. That says the date that you hade this.
Old 04-16-2009, 09:20 AM   #25
70 Suburban
Rods
Im about 1.5 - 2 hours south of dallas
