Old 11-10-2008, 01:10 PM   #1
JNik69SS
69 Big block motor mounts. where to buy?
I am looking for motor mounts for a 69 big block. I got the frame mounts for a big block but cannot seem to find any mounts except year one and they want $171 for them. Can anyone tell me where you can find some of these. Thanks
JNik69SS is offline   Reply With Quote
Old 11-10-2008, 01:27 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: 69 Big block motor mounts. where to buy?
Sorry to say but, that's pretty much the going price for the 68-71 mounts,
I "cheat" by using a small block mount with a longer bolt and a large thick washer, (one from a small block harmonic balancer is perfect) never have had any "issues" yet.
Livrat is offline   Reply With Quote
Old 11-10-2008, 03:38 PM   #3
longhorn70gmc
longhorn70gmc's Avatar
Same Here!!!!!! Cost effective and it gives me time to find the right ones for the right price. I have had them in for 8 years now.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 11-10-2008, 04:32 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I also use the same mounting method..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-10-2008, 07:05 PM   #5
longhorn70gmc
I am glad to here that some others have done the same thing to make up for the cost and lack of 68-71 BB motor mounts. I always had that thought that it was getto, but it works out great.
Billy
Hub Cap Freak!
Old 11-10-2008, 08:08 PM   #6
Mowdigger
Mowdigger's Avatar
look at the motor mounts that autozone has . They are showing motor mounts for a 69 with a big block.
Mowdigger is offline   Reply With Quote
Old 11-10-2008, 10:05 PM   #7
chevy29267truck
The truck shop in CA
chevy29267truck is offline   Reply With Quote
Old 11-10-2008, 11:27 PM   #8
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
What is the difference between BB and SB mounts? I didn’t realize there was a difference…..now , you all got me wondering what is on my 1968 GMC with a 396. I had a 350 in it for a short period of time in high school when I grenade the first 396 and swore I used the same mounts on both the SB and BB. That has been 17 years ago so I may have forgot about changing them.
Hmm, maybe that my truck keeps eating left side engine mounts while detroying fan shrouds in the meantime.
Bad picture but can you tell by this what mounts I have? The towers are indeed BB.
DirtyLarry is offline   Reply With Quote
Old 11-10-2008, 11:56 PM   #9
Livrat
Member #1049
Livrat's Avatar
Can't really tell by your picture. You would have to look under the tower to see if it is two pieces,
Here is a drawing of the factory style 68-70 big block mounts.
Old 11-11-2008, 01:16 AM   #10
DirtyLarry
DirtyLarry's Avatar
Ah, yes…….you’re picture jogged my memory, those are the mounts my GMC has. Man, I didn’t realize they were that hard to come by or expensive these days.
I just did an engine swap on a C20 ’72 with a SB to a ’90 TBI 350 and it didn’t even occur to me that the mounts were different from my GMC. Then again, I haven't had the engine out of my GMC since 1992.
Actually, I converted the ’72 C20 to ’76 saddle type mounts during the swap as the ’90 exhaust manifolds would not clear the SB engine mount towers and will probably do the same to the GMC as I am planning an 8.1L swap in the near future. It seems the ’67 – ’72 engine mounts have a history of breaking and causing plenty of damage while doing so.
Why bother with the original style mounts that have a history of breaking unless it is a full on all original show truck?
This is what I used on the '72....
Old 11-11-2008, 11:52 AM   #11
Livrat
Member #1049
Livrat's Avatar
Some prefer to keep things as they came from the factory even though they do not have a "show truck", Yes the very early mount had a history of breaking but the later versions had a design change with a "built in" failsafe,
I prefer to use the 73 and up towers and mounts, The design is much better but mostly because they are very inexpensive compared to the original Big Block ones. But one has to be careful there, I have run across 3 different styles of towers and several different version of the engine "cup". some will make the engine sit too high and others will not even line up..
Old 04-17-2009, 02:20 AM   #12
westex245
westex245's Avatar
I saw how to modify the 73 and up mounts on here somewhere, but I cant find the page could someone give me the link thanks
westex245 is offline   Reply With Quote
