Old 04-17-2009, 02:33 AM   #1
Hoffman65burb
Hoffman65burb's Avatar
Wiper motor location
Where abouts is the wiper motor located?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 04-17-2009, 02:40 AM   #2
69lemans
Re: Wiper motor location
Inside the cab,under the dash
69lemans is offline   Reply With Quote
Old 04-17-2009, 05:51 AM   #3
Irishpilot
with a flashlight, you should be able to see the bottom of the motor and the wire harness that connects. Remove 3 or 4 bolts and disconnect the wiper arms before pulling. Pretty easy to do, but don't force anything.
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
