04-16-2009, 11:25 PM | #1 |
aftermarket or factory A/C
I'm looking at 3 different trucks for parts for my 3/4 ton 4x4 2 are factory a/c cabs in ok shape, the third has an aftermarket a/c setup but is in very nice shape, is factory a/c worth it or will the aftermarket stuff work
04-17-2009, 02:18 AM | #2 |
AFAIK, all the aftermarket A/C kits pull air from inside the cab. They just cool & recirculate exhaled air. No fresh (outside) air intake option.
Factory A/C had a fresh air option. I hope someone can straighten me out on this because I'd like to learn of an aftermarket A/C kit for 67-72 chevy trucks that can pull fresh, healthy air to cool. The factory R12-based systems should cool better than aftermarket R134 sys by virtue of R12's superiority, but R12 is costly. A pickup cab may not notice any difference compared to a cavernous burb. Tinted windows likely lesson any difference further. Refurbishing a factory system that's in poor shape or missing pieces can easily cost the same as a new aftermarket sys. Also, a factory A/C system requires an A/C cab for the firewall hole locations. Patch welding on a non-A/C cab' firewall can resolve the difference. If the price is right, I'd pick up all the factory sys. Variables abound. Its all in what you want.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
04-17-2009, 05:43 AM | #3 |
WTB this ad
Re: aftermarket or factory A/C
I don't have the patience or desire to nickle and dime a 35 year old system to the point that I've got more in it then a could buy a new aftermarket system for( and have a warranty). I've put aftermarket systems in several vehicles (just did one 2 weeks ago). They may not be perfect (but neither were the stockers) but they're an excellent option for vehicles that don't have factory air and owners that don't want to spend months troubleshooting an antiquated stock system.
04-17-2009, 07:28 AM | #4 |
I agree with Asa, that is the reason we installed a unit from classic auto air. If fact it cools perfect 37 degrees at the outlet and the temperature outside 82 degrees. I can not run it on high I have to keep it on medium or slow.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-17-2009, 09:46 AM | #5 |
Between Trucks...
Also in agreement. Just not worth trying to cobble together a 40 year AC system. The aftermarket systems also look cleaner under the hood.
Beat it to fit, Paint it to match... |
04-17-2009, 10:04 AM | #6 |
Moderator
Factory A/C also pulls air from inside the cab (recirc), if the vacuum hoses are routed properly. Pulling air from the outside does not get as cold. When you put the heater on, it pulls air from the outside, and the re-circ vent in the cab closes up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-17-2009, 10:12 AM | #7 |
It's alsways something.....
Around here, its very common to see trucks with factory a/c installed....what is rare is to ask if it cools and the guy sez that it does.
I installed an "Old Air" brand in mine-The in cab part is about the size of a volleyball and the only thing thru the firewall is the H/C and a/c lines. I love GM factory stuff, but 4o year old a/c stuff is a challange unless you do it right- Break it all down and fix it right, reinstall and have it professionally serviced- JHO, tho |
04-17-2009, 11:17 AM | #8 |
the new aftermarket systems are much more efficient and rob less power and mpg from your drive train
04-17-2009, 12:16 PM | #9 |
thanks for all the input guys, I think I'm going to buy the cab with the aftermarket a/c system in it its in alot better shape than the other two I was looking at. Is there a brand that i don't want? Anything i should look out for? I am a HVAC/refrigeration service tech so hooking it up and servicing won't be a problem.
04-17-2009, 08:14 PM | #10 |
if they can make it so can I!
has anyone tried those universal type from jegs?looks like vintage air stuff kinda...i used the rear air box from a conversion van ...has heater and a/c cores in on box..which also looks like vitage air stuff...not sure how its goin to work , fit good under the dash tho..lol heat works good...no a/c hooked up yet!
