Old 04-17-2009, 07:57 AM   #1
au03z71
au03z71's Avatar
Rim width...
Could I get by with a 20"x10" rim on the back of my 72? I know that an 8.5" is the most forgiving on the front... Also, I want the wheels to be staggered so if I can run a 20"x10" wheel on the rear with a 5.25" b/s, what b/s could I run on the front if I went with a 20"x8.5" wheel for a decent staggered look?
au03z71 is offline   Reply With Quote
Old 04-17-2009, 08:50 AM   #2
SCOTI
SCOTI's Avatar
Re: Rim width...
20x8.5" w/a 5.25bs for up to a 5/7 drop. Anything more (bagged) & you might want 5.75"bs to tuck them in a little more so the tires won't hit the top of the outside edge of the fender lip.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-17-2009, 12:53 PM   #3
au03z71
au03z71's Avatar
Re: Rim width...
Do you think I could get away with a 22"x9"?
Also, what would you suggest for a front b/s for a nice stagger?
Old 04-17-2009, 03:41 PM   #4
SCOTI
SCOTI's Avatar
Re: Rim width...
22x9 would be a tight fit in front. It's do-able, but tight. You would need to measure everything per your truck (there's no generic dimensions when it comes to fitting a 6# package in a 5# spot).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2009, 11:12 AM   #5
au03z71
au03z71's Avatar
Re: Rim width...
Are you talking about the front or the rear?
Old 04-19-2009, 11:26 AM   #6
SCOTI
SCOTI's Avatar
Re: Rim width...
Front.
22x9's will easily fit in the rear. I would measure for verification, but 5.5"bs should be the magic number for the 72 model rear (if everything is centered correctly). 20x10's would be a tight squeeze in factory 67-72 tubs on big-time drops. They'll fit but are going to be close on one side or the other. I used a 5"bs for my 68 & mini-tubbed the tubs < 2" to make sure they wouldn't buzz the outer edge & allow for plenty of clearance on the inner tub. A 72 might not need the mini-tub because the slightly wider width changes the bs needs.
I highly recommend grabbing a plain old steel wheel of a known size & use it as the baseline for determining what will work best on YOUR truck. Once you know the dimensions/bs of your baseline wheel, it's simple addition/subtraction to figure out what you'll need.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2009, 11:39 AM   #7
au03z71
au03z71's Avatar
Re: Rim width...
Front.
Yeah I know that it's virtually impossible to run greater than a 8.5" wide wheel on the front. I had planned on running a 10" wide wheel on the back and an 8.5" wheel on the front. I know I'll need to measure for appropriate backspacing, I was more worried about the 10" wide wheels on the back than the 8.5" wheels on the front.
Old 04-19-2009, 12:13 PM   #8
SCOTI
SCOTI's Avatar
Re: Rim width...
In that case, they'll fit. Just measure using a baseline wheel & you'll have confidence the dimensions are correct for your truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2009, 01:58 PM   #9
au03z71
au03z71's Avatar
Re: Rim width...
Awesome man. Thanks for the advice. Sounds like you might have done this once or twice...
Here are the wheels I'm looking at by the way:
http://www.bossmotorsports.com/custo...els.cfm?id=408
Old 04-19-2009, 02:35 PM   #10
ap2002
Re: Rim width...
i dont know the difference between 68 & 72 but on mine it has 16x10 in the rear and they tuck all the way in, i believe they are on 4.5" backspace?
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 04-19-2009, 02:40 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rim width...
Be forwarned that there will be fitment issues on the front with those wheels.
The low profile center cap will not clear your spindle dust cover. The only option I see that "might" work is order the spinners.
Not my first choice for center caps, but I don't see anything else that will work.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-19-2009, 02:57 PM   #12
au03z71
au03z71's Avatar
Re: Rim width...
Weren't there some clearance issues with Coys too?
Old 04-19-2009, 05:01 PM   #13
SCOTI
SCOTI's Avatar
Re: Rim width...
Yes there were but I've read their newest products for these trucks corrected the issue. The old fixes were to either turn down the snout of the brake rotor hub or add a specer under the center-cap of the wheel. I did the spacer & you couldn't tell it was there unless you looked too see if there was one (I'm that anal).
As for the link you provided on the wheels, what bolt pattern will you be using? I ask this because my initial review of their listing indicates no 20x8.5 in a 5x5 pattern (stock 72 pattern). I also can see they don't offer anything close to the proper back-space requirements for a 72 in the 20x10's (6.225 is too much). That much spacing will require about a 1" billet adapter (which adds to the cost of the wheels....).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2009, 05:16 PM   #14
au03z71
au03z71's Avatar
Re: Rim width...
I saw that too... I'm probably going to go with a set of Coys C-5s instead...
Old 04-19-2009, 05:37 PM   #15
SCOTI
SCOTI's Avatar
Re: Rim width...
In that case 20x8.5 w/5.25bs & 20x10 w/5.50 are common.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2009, 07:27 PM   #16
joe231
joe231's Avatar
Re: Rim width...
Hey SCOTI,
can you point me in the direction of where you read this?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 04-19-2009, 07:47 PM   #17
SCOTI
SCOTI's Avatar
Re: Rim width...
I actually read it on here in one of the Coy's wheels threads.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2009, 07:48 PM   #18
joe231
joe231's Avatar
Re: Rim width...
Cool thanks, I look around for it
CHEVY ONLY
Old 04-20-2009, 12:13 AM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rim width...
Scoti as usual you are spot on with your insight. The Boss wheels do not offer a fitment for our trucks unless you go with 18/18 or 18/20s.
Even then the center cap is an issue that hasn't been resolved.
Articles-
"Refining Sierra"
