Old 04-18-2009, 07:41 PM   #1
prg machine
prg machine's Avatar
Eaton rear axle inspection plate
DRAT!!!
On my K-20, rear axle, I took the cover off because it was leaking and permatexed the heck out of it and am wondering now if it is upside down!!
Does the fill plug go to the left or right side of the vehicle looking at the cover. Going right puts it high going left puts it low. It appears that the bolt pattern is universal allowing this mistake.
DRAT!!
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 04-18-2009, 07:45 PM   #2
prg machine
Re: Eaton rear axle inspection plate
If there is a 50 / 50/ chance guess how it usualy goes!!!!!
I am not in the mood to go through this mess again!!!
383 .040 over
Old 04-18-2009, 08:05 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
my eaton truck isn't here right now... but I think I have a photo of one installed...
And lower left it is!
Special thanks to MTDave for a very old photo of his 72 longhorn.
Old 04-18-2009, 08:05 PM   #4
Tetdoeuf
Invest in Gold!
Tetdoeuf's Avatar
This is what mine looked like...
John
Gold 1970 Chevy LWB Fleet
Tetdoeuf is offline   Reply With Quote
Old 04-18-2009, 10:05 PM   #5
prg machine
Like I said: 50/50 chance and what do ya know? I didn't notice it till I was filling up and thought WOW that fill hole is awful high!
Anyway I pulled it off and started over ..............now it's right. Pays to take a second look always. I was so concerned about getting permatex everywhere and in every hole and on every bolt to stop the drip from the cover that I tripped right into the trap!!!!!
383 .040 over
Old 04-18-2009, 10:15 PM   #6
vectorit
What?
vectorit's Avatar
Since were all showin our rear ends, here is mine... Bein that I missed the Amtrak goin by Mugs away saloon n all
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-19-2009, 02:21 AM   #7
4x4Poet
If you perfectly place the cover on with the drain hole high, it will hit the ring gear.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-19-2009, 11:42 AM   #8
Longhorn Man
filler hole... not the drain.
Old 04-19-2009, 11:50 AM   #9
Shaky
Six in a row makes it go...
Shaky's Avatar
Darn - I've got the only rusty rear.
Shaky is offline   Reply With Quote
Old 04-19-2009, 12:16 PM   #10
Longhorn Man
that means you have one in a billion... yours doesn't leak.(as much)
The eaton diff is kinda known for being a leaker.
Old 04-19-2009, 12:51 PM   #11
factorystock
factorystock's Avatar
The gasket kit is still available at some auto parts stores. There are 2 different thickness gaskets, they say the thin one is for the front pumkin and the thick one is for the cover?
factorystock is offline   Reply With Quote
Old 04-19-2009, 01:24 PM   #12
prg machine
It didn't seem to in my case or perhaps that would have tipped me off. I have the 4:10 if that is a different diameter perhaps???? Regardless, I didn't run it till I turned it back over to the correct position. Only took another hour to remove and start over. Some of my leak comes from the pinion seal I do believe. The worst thing bout em is that the bolt holes go straight through and if threads aren't gooped up good the oil seeps through the bolt holes!!
383 .040 over
