Old 04-16-2009, 09:20 PM   #1
truckluv
tach prombles
just wanting to know is the stock tach.they tell me i have to buy a tachometer
adaptor.in oder to make it work with a HEI Distributor.is this true?please let me know if this is true.thanks leroy.
truckluv is offline   Reply With Quote
Old 04-16-2009, 09:31 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: tach prombles
Nope it's not true, a factory tack will wire right up to an HEI dist.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-16-2009, 11:35 PM   #3
truckluv
Re: tach prombles
thank you for your response.but i know it will wire up.that not the promble.it works. but it is not working right.it works but very little.the rpm comes up but only a bit.when i give it the gas.it barley rises.the tech at classic industries. said i need a tach adaptor so it will read right.the after market tach. says note:tachs are NOT for use with HEI DIST,IF ANY BODY KNOWS LET ME KNOW PLEASE. THANKS VERY MUCH LEROY. MY PHONE NUMBER IS 573-308-6722.
Old 04-16-2009, 11:50 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
Re: tach prombles
The only "tach adapter" that I am aware of is used when dealing with a newer style engine with things such as "Coil on plug" ignitions etc. Just for clarification, what year truck/engine are you dealing with???
Also, a V8 engine needs a V8 tach, 6 cylinder needs a 6 cylinder tach..etc.
Old 04-17-2009, 12:29 AM   #5
truckluv
Re: tach prombles
The tach came out of a 67 chevy big truck.with and old dist.and coil pack on it. My truck is a 68 chevy with a 396 big block in it.and a hei dist.and the tach is not working or reading right.it moves but just a little bit.something is wrong.
Old 04-17-2009, 12:52 AM   #6
Critter
Future TOTM Winner
Critter's Avatar
Re: tach prombles
The "big truck" part is a little questionable to me. Some were V8 some were V6...
Assuming your tach is for a V8, and lets also assume the tach wire is connected to the proper terminal on the HEI and the guage is grounded properly. If all that is good then I would say that you possibly have a bad tach. Have you seen it work correctly previously or is this your first time to hook it up?
These original tachs should all have "V8" or "V6" stamped on the back of them.
Old 04-17-2009, 01:02 AM   #7
Critter
Future TOTM Winner
Critter's Avatar
Re: tach prombles
I hate not being able to edit anymore...
I said V6 before...meant Inline 6
Old 04-17-2009, 08:56 AM   #8
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: tach prombles
Critter hit it on the head of the nail.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-19-2009, 09:36 PM   #9
DANTES JIMMY
DANTES JIMMY's Avatar
Re: tach prombles
Well not only inline 6 cyls but didnt they have some huge cubic inch v6 like in the 380's??
DANTES JIMMY is offline   Reply With Quote
Old 04-19-2009, 10:15 PM   #10
Critter
Future TOTM Winner
Critter's Avatar
Re: tach prombles
Yep, they had big V6s but only in the GMCs, he said he got it from a big chevy, no V6s in the Chevys.
