Old 03-19-2003, 08:26 PM   #1
mudman
camaro tach- I screwed up
I just got a camaro tach to install in my cluster. I did a really stupid thing though. I was trying to find out if the original needle off of a speedometer would fit on it. Well I found out that it wouldn't fit but I think that the tach moved when I tried to put the correct needle back on. Does anyone know how to put it on in the correct place ? When i put 12 volts to the needle points to 1000 RPM. Is this right or should it be on 0? Thanks for helping me. I knew that I shouldn't have taken it off.
mudman is offline   Reply With Quote
Old 03-19-2003, 08:35 PM   #2
crazy4chevs
crazy4chevs's Avatar
I believe that with the ignition off its at 1000 and with it on (not running) its at 0
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 03-20-2003, 04:19 AM   #3
dmec
dmec's Avatar
sorry to hear you removed the pointer. i havent had success doing that, so i leave them alone. try putting needle on when 12 volts are applied. should read zero. also try grounding the ground stud with 12 volts applied and see what happens.
dmec is offline   Reply With Quote
Old 03-20-2003, 04:49 AM   #4
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
There is not a sure 'zero' place for the tach, it is best to stick on the needle, use a separate meter, note the difference, then move the needle while holding the shaft with needle nose pliers, then check.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
