Proper Tire Size
1970 Chevy CST-10 came from previous owner with 235-70-15" tires on original Chevy 15X8 rally wheels. Love the rally wheel look so I want to keep them. The tires look a bit small though...could be just me?..I've looked over the body/glove box tags but cannot find anywhere what size tires the truck came from the factory with. Anyone know?
Thanks, Bob
I'm a grateful Christian not perfect in any way, but always striving to become better with Christ's help. I'm grateful for what He did for me on that cross at Calvary. I hope there is a desire in your heart for the same: If you confess with your mouth that Jesus is Lord and believe in your heart that God raised him from the dead, you will be saved. Romans 10:9 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Proper Tire Size
The closest radial to original size is a 235/75/15. Your tires look short due to the 70 series instead of the correct 75 series.
That little difference between a 70 and a 75 series profile affects the overall tire height by right at an inch. In my opinion, I prefer to run 275/60/15 tires. They are the same overall height as stock tires were, but a good bit wider and they look very good on rally wheels. This tire was the stock size on Chevy's 454ss truck in the 90s.
from reading here they came with letter designation. and i am too young to remember anything about them. as i recall though the stock letter tire converted to metric equalled between 225 75 15 and 235 75 15. longhorn man will know. i too am wrangling what size to use. i think i will run 225 70 in front and 245 70 in rear here is a linkhttp://www.ajdesigner.com/fl_tire/tire.php to a calculator. it will tell you the difference in measurements height width circumfrence etc. of each size. kind of fun to play with.
#4 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
<object width="300" height="605"><param name="movie" value="http://media.ajdesigner.com/fl/tire.swf"></param><embed src="http://media.ajdesigner.com/fl/tire.swf" type="application/x-shockwave-flash" width="300" height="605"></embed></object><br><a href="http://www.ajdesigner.com/index.htm">By AJ Design Software</a>
laying low
![]() Join Date: Mar 2001
The original letter designation sized tire would probably have been a G78/15 and the modern metric sized equivalent is about a 235/78/15. If the 235 looks a bit narrow for the rally wheels you can step up to a 255/70/15, same diameter and a touch wider. I run them.
#9 | |
its all about the +6 inches
Thanks everyone for your input. Well....The previous owner that put these tires on wasn't too far off then....sounds like only 1 size too small...My local tire shop guy said that 255/70r/15's would be about right, so I guess he wasn't too far off either.
To 70CST:...You know...I did not know that our trucks didn't come with rallys...so thanks for the info. When did Chevy start putting them on their trucks? The cars were getting them in 70....right? Thanks again guys...You've been a big help to me. Bob
they showed up in 73
![]() Join Date: Jan 2007
my glove box show's h78-15 not sure what that converts over to but i think i will be going to 275/60r15 for the width
