Old 04-16-2009, 11:37 AM   #76
project69c10
project69c10's Avatar
Re: Poor mans drop
Cut them or have some body do it for you.i know when i started to build project 69c10,a good friend of mine owned a junk yard,and sold me a set of ccoils for 10 bucks and cut them down to size,thank god for good friends.wow your truck looks like mine did ,mine is a 69 long bed same color same rims what a flash back
project69c10 is offline   Reply With Quote
Old 04-18-2009, 08:59 PM   #77
ratridechevy454
Re: Poor mans drop
Ok if you lower with chevelle springs and put 2" blocks in to get aprox a 4" drop how about the rearend track locate bar? Can you retain the stock one or need a adjustable one?
ratridechevy454 is offline   Reply With Quote
Old 04-18-2009, 09:09 PM   #78
project 67 sub
project 67 sub's Avatar
Re: Poor mans drop
you could always temporarily bend the stock one to center your wheels until you can buy an ajustable one, or build a longer one and relocate the diff mounting point like im doing.
project 67 sub is offline   Reply With Quote
Old 04-19-2009, 07:15 AM   #79
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Poor mans drop
how much will it need to be shortened??? i'm bagged now with a notch and was thinking it would be a good time to do that before I put the bed back on.......I guess I could measure it if I wasn't so busy doing other stuff....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-19-2009, 11:33 PM   #80
project 67 sub
Re: Poor mans drop
that depends on how low you go. if its lowered anything over 5"s it will end up being to short. when mine was lowered 5"s in the rear, i only bent it as much as needed. now that im lowered 9"s it was to short even when it was not bent, so i got one off a 66 c-20 coilspring truck and bent it to where i needed it, until i can finish my extended one.
Old 04-20-2009, 06:03 AM   #81
Hottrucks
Hottrucks's Avatar
Re: Poor mans drop
I'm bagged with a C notch....not even sure how much drop that equals????
Old 04-20-2009, 04:49 PM   #82
Shane
Shane's Avatar
Re: Poor mans drop
Or you could do it the right way ... and I just happen to have something that might help ya out.
Shane is offline   Reply With Quote
Old 04-20-2009, 08:18 PM   #83
project 67 sub
Re: Poor mans drop
im doing mine the right way too, the bent one is only temporary until i finish my new one im building. and it isnt costing me anything to do it
Old 04-20-2009, 08:50 PM   #84
Hottrucks
Hottrucks's Avatar
Re: Poor mans drop
well I'm lucky enough to live in a big race car area and they have them hanging on the walls everywhere...( the dirt guys bend them up pretty regularly)...I got my c notchs cut/welded today and bed on so a quick measurement and a 2 sec drive and I'm at the store to pick one up...... seems to need to be about an inch shorter but maybe tomorrow my cab and bed mounts will be in so I can get a better idea once things are put where they are going to live.......
