Rust trouble spots
Finally decided to start getting serious on the old workhorse. I've started sanding down the paint and putting a temporary primer coat on but I'm trying to find all the rust and trouble spots on the truck before I get any body work done just to know where i'm at.
I dont plan on rebuilding the truck from ground up but i would like to at least get it nice and solid before I throw more money into it. I found all the usual locations for rust, RH rocker, RH floor pan, it looks like the wheel wells up towards the grill are shot. the bed running along the tailgate and LH cab corner. Any ideas on where to look underneath or other spots? The frame seems pretty solid, I havent looked real closely yet but I just hate to get it in the body shop and find more issues. heres a few pics
1968 GMC 3/4 ton 2wd, 350ci TH350 1966 Pontiac Lemans, 326ci TH350 1966 Chevrolet El Camino, 327ci TH350 2003 GMC Sierra 4.8l, reg. cab swb |
Re: Rust trouble spots
inner rockers and supports.. front and rear pillars and footwell/kick panel was the other spots mine was rusted out at... and bed crossmembers
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Moderator
![]() Join Date: May 2007
Under the RH front fender it usually rusts out from leaking batteries over the years.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#4 | |
thanks for the input guys, fingers crossed i dont find any more cancer....
take the time now to remove and replace the drip check on your drip rail. take a good look at the cab supports.
Trueman Last edited by 463; 04-16-2009 at 05:38 PM. |
above the sunvisors..
More bad news, There is a support running across the bed aft of the rear end above the leaf spring that is shot (crossmember?), also the supports underneath where the fender and cab come together are rusted through on both sides. the drip rails seem to be in ok shape except on small portion on the passenger side where the door fits in.
This seems like all the new stuff Ive found. i'll have to do a double take just to make sure. Did find out that its got a Dana 60 in the Rear. One small highlight. thanks for all the pointers, lemme know if y'all have any more!
![]() Join Date: Dec 2008
The vent boxes behind the front fenders. Anywhere that is connected to the vent system because of the giant holes in the cowl.
if u take time it can be done by yourself..
#10 | |
Tim, I wish I had the experience to fix a lot of these issues but I literally have zero experience with cutting and welding, I know i'd just butcher it up even worse...
i didnt have much experience either.. i had a friend come stop by and help but once we took the time and did it.. it wasnt to bad.. time is your enemy thats the only drawback... i dont think you can make it worse then it is... you dont have to fix it like 100% i mean like the welds can be bad since most of it will be covered up anyways
Under Construction
good luck with your build....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Hell, if I knew what to look for 15 yrs ago when I bought my truck I probably would have left it where it was!
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
#14 | |
I'd love to be able to handle all the work but with it comes having all the correct tools and resources. Which right now I just cant afford. I know this truck wont ever be worth what I put into it but you also dont see too many GMC 3/4 ton 2wd on the road like this, most have been beaten to death by hard work and mine is no exception but theres no reason for it to be used as a parts truck. In the mean time I'll keep gettin my hands dirty sandin this beast down. Thanks for all the input and I'll be sure to keep y'all posted on further progress and/or frustrating problems!
#15 |
it reminds me of mine before i restored it. had rust all over
1972 longbed- 454 1967 shortbed- 355 |
