Old 04-24-2009, 09:06 PM   #1
SeventyOne
Re: Suspension / Driveline set-up questions
Originally Posted by RckyMntnKng View Post
I can answer the angle question.....Whatever angle your Xfer case is at is what you try to match on your diff angle. The goal is to get them parallel as possible, so the rotational speed at both ends is the same....ie no harsh vibrations.
Right - but I plan on doing a CV style so I won't be matching angles I will be pointing my pinion up at the T-case so there essentially is no angular disparity between the pinion yoke angle and the driveshaft itself.
My question was how do I know I am within the "tolerance zone" of a CV shaft? How do I know I have rotated it enough or too far?
I guess I have been assuming there is no shaft between the T-case and pinion to know when you hit the right angle...Is this what I am missing? So use the stock shaft, set the angle, get new measurements for a new shaft?
SeventyOne is offline   Reply With Quote
Old 04-27-2009, 10:29 AM   #2
Burt4x4
Burt4x4's Avatar
CV shaft is perrty forgiving but I would guess if you get out of the tolerance zone you will experance massive vibrations and pinnnion angle too high will mess with diff oil levels and splashablity or slingablity of the gear oil = HOT rearend
For mesurement without a shaft installed just point the pinnion at the xfer case and measure (cap center to cap center), when they make the shaft it will have in/out movemnt that will alow your mesurement some flexabilty, so it doesn't have to be a super perfect mesurement.
.02cents
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
