Old 04-22-2009, 08:16 PM   #1
XXL
Señor Member
XXL's Avatar
71-72 front rotor hub dimensions
Anyone got a caliper handy and a wheel off their 71+ disc brake setup? I'm looking for the dimensions for the snout (including dust cap) to ensure a wheel with a center bore of 3.07" and hub depth of 2.75" will fit.
XXL is offline   Reply With Quote
Old 04-23-2009, 09:05 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 71-72 front rotor hub dimensions
Hey ken if i caers I LL GET THE MEASUREMENT FOR YA..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-25-2009, 03:15 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Ken it looks like my dog ate my calipers or someone walked off with them..
MEMBER #6377
Project "7DEUCE"
Old 04-25-2009, 04:00 AM   #4
XXL
Señor Member
XXL's Avatar
No problem on my end. But if your dog ate them, you're going to have problems in a few hours *gulp*
Old 04-25-2009, 10:48 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
I have 3.06 and 1.75. You should be good. In return, I would like to know what kind of wheels you're gonna use.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-25-2009, 11:00 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
XXL,... I measured my blazer rotors. The hub diameter was about 3.030" and the depth was 2.875".
They are ECE cross-drilled 5 lug rotors and with new ECE dust caps.
I also measured the bore of a 5 lug ralley. I came up with 3.035".
Hope this helps.
Keith
Convert to disc brakes.
Old 04-25-2009, 11:05 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Doh! Go with lolife's numbers. I just realized my loose rotors are 1" thick, so the bore would be the same but the snout is shorter- and I didn't include the dust cap...
-Chris
Old 04-25-2009, 11:35 AM   #8
lolife99
lolife99's Avatar
My rotor are 1-1/4" thick, if that makes a difference.
Keith
Old 04-25-2009, 01:19 PM   #9
XXL
Señor Member
XXL's Avatar
Sounds like a worst case of the dreaded cap doesn't fit syndrome. Or best case, they work fine. I'll let you know on the wheel type once I get them... I need a head start on the crowd
Old 04-25-2009, 03:02 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Cap no-fit is easily curable with an angle grinder- with no ill effects to the rotors...
-Chris
Old 04-25-2009, 03:06 PM   #11
XXL
Señor Member
XXL's Avatar
Current wheels have been capless for 10 years (next month), so as you can see, I am flexible on this point
