454 MAKES IT ROAR
Sway Bar Rivets.
A while ago I discovered that one of the two Rivets on my front sway bar was missing so I put a nut and bolt in there and forgot about it, then a while later noticed that it had worked loose so I added a lock nut with the split washer and it still worked loose. Now checking it the other day to see if it had loosened since, I found that it had and the one remaining Rivet had disappeared, sheared off I suppose....My question is this....is it essential that the sway bar brackets are Riveted on and not Bolted? If so how the heck do you install Rivets without working in a ship yard?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Roadtrip!
![]() Join Date: Feb 2003
Re: Sway Bar Rivets.
I don't know why you couldn't use bolts with lock washers. You could use grade 8 stuff for piece of mind...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
laying low
![]() Join Date: Mar 2001
8B. Is that thumpin big block shaking the frame apart?
all you need to rivet something is a metal rod a torch and a hammer and dolly plus a bit of imagination
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-26-2009 at 01:48 PM. |
#5 | ||
454 MAKES IT ROAR
![]() ![]() Do you guys have Bolts or Rivets?
![]() Join Date: Jul 2004
Added sway bars to two of our trucks, just use grade 5 minimum, (3 lines) or better yet use grade 8, (6 lines). If you look at the factory bolts that hold the bushings on you will see that they are 3 line (grade5), we used grade 8 bolts, lock washers and nuts just to be sure, the plating is ususally better on the grade 8 also and won't tarnish as fast and look new longer.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#7 | ||
454 MAKES IT ROAR
![]() Quote:
Green when you say "lines" are you refering to the small lines that I have seen on the heads of the Bolts on my Truck?
![]() Join Date: Apr 2009
Sisyphus was my mentor!
![]() Join Date: Sep 2002
The parts are only as good as what holds it together. I try & use the best bolt for the job, & that doesn’t necessarily mean using a Grade 8 nut/bolt on everything as they are expensive. You don’t need Grade 8 hardware to hold your glove box door on. (Unless you're REALLY hardcore!) There's a time & a place for the high strength stuff. Your application eightbanger is Grade 8 country. In my sway bar installation, I used Grade 8 bolts with hardened washers & Grade 8 nylon locknuts. I haven’t checked them in a while, but I'm confident they are at what I torqued them to 5 years ago.
http://www.boltdepot.com/fastener-in...ade-Chart.aspx http://www.americanfastener.com/tech...ings_steel.asp http://www.rockcrawler.com/techrepor...ners/index.asp
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 04-26-2009 at 03:10 PM. Reason: Spelling... |
Yep - basic bolts are grade 2, no lines, have no purpose being used on any vehicle, except maybe some non critical small part fastner. Grade 5 - 3 lines are the most common bolt to use on engine, tranny etc, most all bolts. Grade 8 have 6 lines and should be used where failure is not acceptable or could be a safety problem, suspension etc. Most shock bolts are only grade 5, but they are a fairly large bolt.
Yes, look at the head, no lines=gr 2, 3 lines=gr 5, 6 lines = gr 8. Just take the number of lines and add 2, that will give the grade. Most nuts and locks used with grade 5 are grade 2, thats OK. Step up to the grade 8 and the bolts, locks, nuts and washers all have a yellow plating and are the better stuff.
Eat My Rust
If you need some Grade 8, and have a friend in the service department of a GM dealership, or just feel lucky, ask if you can buy off some of their stash. GM Dealerships are required to carry Standard bolt sized Grade 8 bolts. But, since all modern cars use Metric bolts, the dealerships rarely use them. I got lucky, and got all my grade 8 bolts for my truck for free. But my dad works in the service department. But you can try and find one that will let you have some for cheap, considering they have no use for standard bolts.
#12 | |||
454 MAKES IT ROAR
That's an idea! should have tried that. Thanks 71 GMC SHORTY
Man if only I had a GM dealership here....I'd think I died and gone to heaven. ![]() Thanks texan. Well i'm an educated man again....until I find the next thing I don't understand. I have to say you guys are the best and that goes out to everyone else on our board too. ![]()
SWB 4X4 CLUB
Tractor supply sales grade eight at a reasonable price.
Jason |
If you cant find grade 5 or 8 bolts where your at you might try a metric equivalent, a 10.9 or 12.9 stamped on the head of the metric bolt should be close to the same.
