Active Member
![]() Join Date: Apr 2005
Screws for a/c vent housings?
I need to know what size screws or the length of the screws that i need for the ac vent housing on the jimmy....any help would be appreciated!
#2 | |
The Older Generation
Re: Screws for a/c vent housings?
The top screws are 2 1/4" long oval head trim screws. The two bottom ones are 1/2" long oval head trim screws. Just in case you aren't familiar with them, trim screws have a smaller head than regular oval head screws. Check with your local body or upholstery shop. They usually keep a good supply of oval head trim screws on hand. The long ones may be a problem though... If you use regular oval head screws don't tighten them all the way up or you will crack the vents.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-27-2009 at 11:16 AM. |
