03-20-2003, 04:05 PM | #1 |
removing dash pad
Hey all I am trying to remove my dash pad from my 68. Is it glued on or what? I have removed the screws but it doesnt want to budge. Thanks
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
03-20-2003, 04:18 PM | #2 |
There's some nuts on the backside, about 5 or 6, if you remove your glovebox liner you'll be able to get at the ones on the right side. pull your dash panel to get at the left side. There's one thats hard to get at up above the radio. Hope that helps
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
03-20-2003, 07:53 PM | #3 |
SLOW BUT SURE,BUT CLOSER
Yep 1971 covered it right the one over the radio is hard unless you pull the radio.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
03-20-2003, 08:25 PM | #4 |
Just so you don't have to mess around seeing what fits, it is held on by 3/8" speed nuts. I just loosened the left half on mine to puy my home made tach mount under it. It is much easier to take off than put on.
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
03-20-2003, 09:00 PM | #5 |
cool thanks all. I will try it later
