04-26-2009, 09:14 PM | #1 |
Cab differences?
Hey guys and gals. I have a question about the cabs on the 67-72 trucks. My '67 small window GMC is in desparate need of a replacement cab. I was wondering if there were any major changes in the 67-72 cabs or if they are all interchangable. I would like to keep the original small window look if possible. Thanks in advance.
04-26-2009, 09:16 PM | #2 |
Re: Cab differences?
67 is small window. 68 is big window.. a 71 rear view mounts on the roof and a 72 rear view mounts to the windshield... i think thats only difference
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
04-26-2009, 09:28 PM | #3 |
its all about the +6 inches
there are a bunch of little things that simply don't matter. The main things you'll find that may matter to you... may not...
67 is the only year for a small window 67/68 has the wire harness like yours, chainged in 69 67/67 has the parking brake like yours, chainged in 69. 71/72 has a cable operated throttle, that, while is actually a step forward, would be more hassle when converting. If your truck is a 4 speed, or a 4X4, the high hump issue may be more work for you, but that'll unbolt from your original cab and can be bolted to a low hump cab once you cut out the hole. A/C verses non A/C... not a HUGE issue, unless you have a preference and refuse to go in the oposite direction you are at now. Last edited by Longhorn Man; 04-26-2009 at 09:28 PM. |
04-27-2009, 06:44 PM | #4 |
Sounds like if I want to keep it original looking, I need a '67 cab. I would like to keep the small window if possible. Thanks for the replies!
04-27-2009, 06:59 PM | #5 |
Between Trucks...
The ignition switch bezels different on a '67 as well.
Beat it to fit, Paint it to match... Last edited by Sinister; 04-27-2009 at 06:59 PM. |
04-27-2009, 09:42 PM | #6 |
I heard that a 67s frame is different to where you cant bolt a power steering box to it,does anyone know if this is true
04-27-2009, 10:38 PM | #7 | |
the ign bezels are different, the years are 67-68, and 68-72, some time during the 68 production year they changed
the mayjor difference between wiring harness on 67-68's and 69-72's are the 67-68 haveing a hand pull ebrake allowed for the fuse block to horizontaly on the floor/firewall where as the 69-72's foot opperated ebrake forced gm to mount the fust block verticaly to allow the ebrake full motion on 67 doors the handles are different and wil only work with 67 outer handles, 68-71 doors are completely the same, but 72 doors have a screw on the inside a inch or 2 below the window chnnel attached to the vet window, and also have longer posts for the window crank and interior door handle, which was to provide the space needed to use the plastic 72 door pannels
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
04-27-2009, 10:47 PM | #8 |
Yes,`67 frames never had a power steering box.They require a dimple to be mounted and there are spacers made.ou could rig something up to space the box,but do it right.
