little mudder
i am gonna be turning my s10 blazer to a mud truck i plan to run 31 10.5 on it has anyone lifted these or know cheap ways other than a body lift?
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's Last edited by mothertrucker424; 04-23-2009 at 08:04 PM. |
Re: little mudder
i 4link with steel plates for shocks because if its only used for mud bogging you dont want any flex.
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
Re: little mudder
crank up the torsion bars and add blocks in the rear... you asked for cheap...
or a cheap body lift...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: little mudder
i was going to say is it a ifs and the rear leafs over the axle or under.
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: little mudder
find a rusted out k10 blazer and put the body on it. Those s10's on fullsize frames kick booty around here at the bogs.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Re: little mudder
axle under so i was thinking shackles and crank torsion and still to low
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
