03-20-2003, 03:47 PM | #1 |
Motor HELP
My truck bauging out. I start the truck up drive it down the road maybe a mile. Then it just baugs out and dies. Then it takes a few minutes to get it started again. I checked the fuel pump and carb they both seem to be working fine. Please help if you know what is going on with this. Thanks
03-20-2003, 03:49 PM | #2 |
Oh the motor is a 305 if that matters
03-20-2003, 03:56 PM | #3 |
Project 7dos
I had this problem a couple weeks ago..I have the blazer gas tank under the bed and it was brand new when i bought it, so the tank was a little dirty. I would start the truck, give it a little throttle and it would just bog out and die, than i would park it for about ten minutes and it would start right up. I checked the FUEL FILTER NOT THE FUEL PUMP!!!!!!! and it was real dirty so I replaced it and have never had another problem...
Hope this helps Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 Last edited by chevjayfsd; 03-20-2003 at 04:23 PM. |
03-20-2003, 04:11 PM | #4 |
KEEP ON TRUCKING
yea check the filter first
72 cheyenne 2wd lwb 71 k20 sons bassett va |
03-20-2003, 04:50 PM | #5 |
I made the mistake of starting at the carb and replacing things back.......
Only to find out that one of the rubber fuel lines had calapsed inside......replaced those and rolled right along.................. Hose is cheap..............
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
03-21-2003, 08:30 AM | #6 |
Thanks for your help.
