Old 04-30-2009, 07:44 PM   #1
dmsteele92831
Lowering Block Kit- Will this work
Will this work on a 68 chevy c-10 that has coils in the rear?
http://www.jegs.com/i/JEGS/555/60802/10002/-1
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 04-30-2009, 08:28 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Lowering Block Kit- Will this work
Measure the pads and see. I think it's the right one.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-30-2009, 08:36 PM   #3
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
I don't think those are going to work. It say's for leaf springs, it will have locating pins that won't sit right with the axle mounts. The blocks you need are flat bar stock with 2 holes drilled in them. See my example below. These I made to fit mine. Also check in the FAQ's I know there is a post in there on how to build them. Cpp, EEC, Perhaps Bell Tech may sell the right kits.
MT71c-10 is offline   Reply With Quote
Old 04-30-2009, 08:41 PM   #4
Andy4639
Old member
Andy4639's Avatar
My bad. I started typing before reading it good, sorry. They want work
MT71c-10,
Thanks for showing me the right answer!
Old 04-30-2009, 08:50 PM   #5
MT71c-10
MT71c-10's Avatar
No problem, Just trying to help!
Old 04-30-2009, 09:29 PM   #6
dmsteele92831
From everywhere I was checking I couldn't find a full kit for them. I'd rather just pay a little more than having to drive from place to place and get u bolts made and 3" tube bar cut... oh well!
Thanks!
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 04-30-2009, 09:35 PM   #7
MT71c-10
MT71c-10's Avatar
Just check with some of the aftermarket supplyers. Block kits are made for these trucks.
