Old 04-23-2009, 12:06 AM   #1
c0rey
88 Suburban Fuel Pump Wiring
I got a 1988 suburban and since the day I have got it the gas gauge is pegged out and the guy ran a wire from the fuse box to the fuel pump plug(connection between the wiring harness and pump harness). I unhooked the jumper wire and here is what I got.
Unhooked there is one keyed source power wire. Ok good.
Connect the connector and the keyed source power wire becomes a dead wire.
So something isnt right here and my pump wont work like its suppose to.
The sending unit reads pegged full with the jumper hooked up, and empty with just the connector hooked in.
c0rey is offline   Reply With Quote
Old 04-23-2009, 06:38 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: 88 Suburban Fuel Pump Wiring
Anyone?
tvblazer78 is offline   Reply With Quote
Old 04-30-2009, 01:40 AM   #3
c0rey
Do these have a fuel pump safety switch?
Old 04-30-2009, 07:55 AM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
I think they do, but I could not say for sure.
Old 04-30-2009, 08:27 PM   #5
ChevyTech
These don’t have a safety switch like a ford.
It sounds to me like the ground wire for the tank sending unit has lost connection.
Attach a jumper wire to a good clean ground and the outside of the sending unit and see what happens.
