Old 05-01-2009, 02:41 PM   #1
ChicoSmith
When in doubt throttle out!!!
ChicoSmith's Avatar
68 c20 Brake Booster Hiss
I have a leak near the rubber grommet where the plastic check valve inserts from the vacuum. I noticed fluid missing in the master cylinder reservoir closest to the cab and no pressure in the pedal during braking.
Any words of wisdom from those who've dealt with this problem in the past.
ChicoSmith is offline   Reply With Quote
Old 05-01-2009, 03:00 PM   #2
sleepertruck72
sleepertruck72's Avatar
Re: 68 c20 Brake Booster Hiss
My 72 C20 had the same problem with the reservoir closest to the firewall. I changed my rear wheel cylinders and I dont have that problem anymore. As for the check valve, If its not squared up against the booster it will hiss. Try replacing the vacuum line and leave it long enough to where the check valve sits flat against the booster.I would probly replace the check valve while youre at it.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 05-01-2009, 03:50 PM   #3
nightmare
nightmare's Avatar
you may also have a leak behind the master cylinder. do you see fluid on the booster under the master? if you do, your master cylinder is bad, and you need to replace it.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-01-2009, 04:11 PM   #4
ChicoSmith
ChicoSmith's Avatar
Thanks guys.
Replaced the valve at lunch today and filled up the master cylinder, took it for a tester and it was a little better. Still not a whole lot of stopping until I just about hit the floor.
Old 05-01-2009, 04:13 PM   #5
nightmare
nightmare's Avatar
yeah, if you've driven it several miles without fluid in the master, then you probably have air in the line after filling it back up. best to go ahead and bleed the brakes to get the correct pressure.
Mike
67-72 FAQ
Old 05-01-2009, 04:18 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
odds are you need a master cylinder. Look at the inside of the wheels. If they are dry, no oil lookin fluid all over the inside of them, then you might as well just go buy a new master cylinder, they are dirt cheap.
When you get it, read the paper in the box about adjusting the pushrod.
If you have any hissing and it is not from the check valve, then a new booster will be needed too. The 3/4 ton and one ton units can be hard to diagnose sometimes. Does the engine idle funny at all?
Old 05-01-2009, 04:26 PM   #7
ChicoSmith
ChicoSmith's Avatar
Just replaced the master cylinder about a month ago, hissing is gone with the new valve grommet part.
No fluid in the wheels from the wheel cylinders or around booster, and the master cylinder never got to the point of pulling air.
Yes it does idle a little rough but seems to be smoother with the new check valve. I could have been losing fluid through the old one?
No paper in the box about adjusting the pushrod.
Old 05-01-2009, 05:24 PM   #8
Longhorn Man
For grins, fire up the truck, unplug that vac line, and put your thumb over the host to block off the suction. See if it idles better. You may have a bad booster.
Brake fluid gets in there and eats the rubber diaphram.
