Old 04-28-2009, 11:04 PM   #26
joe231
joe231's Avatar
Re: 8 lug convert or leave it?
Around '97 ford changed their 8 lug bolt circle to a different size...something metric...and at some point around the same time they went to hub centric wheels, meaning the wheel was centered by the hub instead of by conical lug nuts.
That shouldn't be an issue for you if you get pre '97 wheels
Before that all 8 lugs would interchange, you just need to check backspace
Those caps Tony has are stock caps that go with those wheels.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 04-29-2009, 01:45 AM   #27
six5
six5's Avatar
Originally Posted by N2TRUX View Post
What are you going to use the truck for? If your using it for hauling loads of any kind, the larger hubs, brakes etc that come with an 8 lug set up are worth keeping.
If not, then covert. The wheel selection is a 1000 times better.
Since the Diesel truck craze they make a lot of 8 lug rims now.
I picked up this KMC 20" rim for free. But the backspacing was wrong. So I purchased the KMC Revolvers in all black....
-Dave
My 1965 build...http://67-72chevytrucks.com/vboard/s...d.php?t=331302
six5 is offline   Reply With Quote
Old 04-29-2009, 07:08 PM   #28
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
i don't know what year the wheels i have are... I can ask the guy i bought them from, but i don't know if he'd know. I can get a pic up of the wheels if he doesn't know. I'm assuming they'd be older than 97' though being that the guy doesn't have anything newer than early 80's... he's stuck in another generation.
exmonkeypunk is offline   Reply With Quote
Old 05-01-2009, 03:57 PM   #29
protrash64
Resistance is Futile
protrash64's Avatar
Those 8-luggers six5 is/are running look freakin sick!!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-01-2009, 05:02 PM   #30
six5
six5's Avatar
Hey Pro the rims won't be released for a month. So I won't actually have them in my possession until the end of May. But they will be worth the wait.....
-Dave
Old 05-01-2009, 05:09 PM   #31
joe231
joe231's Avatar
here are the 8 luggers I have been eyeing
CHEVY ONLY
Old 05-01-2009, 05:10 PM   #32
six5
six5's Avatar
Nice bronze.......!!!!
-Dave
Old 05-01-2009, 05:12 PM   #33
joe231
joe231's Avatar
yeah, that pic sucks...but I LOVE the finish on them.....don't even have the truck yet...but I'm daydreaming about wheels
CHEVY ONLY
Old 05-01-2009, 05:15 PM   #34
six5
six5's Avatar
Everything starts with a dream.......!!!!
-Dave
Old 05-01-2009, 09:07 PM   #35
protrash64
protrash64's Avatar
I guess I wouldnt shy away from an 8-lugger now.......I'd just leave 4 lugs off every wheel in case of a flat. Does that mean a Honda wheel will fit?
Old 05-01-2009, 10:34 PM   #36
joe231
joe231's Avatar
CHEVY ONLY
Old 05-27-2009, 07:40 PM   #37
jr2k3_esq
Going from 8 lug to 6 or 5 lug depends on the look you are going for with the truck.
Generally all or most 8 lug wheels will have a high (possative) offset, and big bulky center caps to cover the large 3/4 or 1 ton hub.
5 lug wheels generally have a lower offset with more options for a deep dish wheel, and more options with center caps that will sit flush with the face of the wheel.
I am about to start a 5 lug swap on my '70 8 lug simply because there are more options for lowering it, and more options on wheels. I can agree that there are more options for 8 lug than there was before (I work at a tire shop), but whenever I see them I think 4x4. My truck is a 2wd and I want to go this route to gain a 2wd sweet looking wheel, and disc brakes.
jr2k3_esq is offline   Reply With Quote
