Old 05-01-2009, 09:23 PM   #1
Korr053
Question Mystery drivetrain noise help!
Hi, I have a 71' C30 dually that has me and all my shadetree buddies stumped.
The problem is when driving I'm getting a terrible howl/grinding/scream from somewhere in the drivetrain. (I think) The noise isn't bad in low gears but when I get into fourth and get going 45-55 it screams. When I press in the clutch it stops. I replaced the tranny, a sm420, and the clutch with no luck. Dosn't sound like the rearend, any ideas? Thanks!
Korr053 is offline   Reply With Quote
Old 05-01-2009, 10:28 PM   #2
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Re: Mystery drivetrain noise help!
I would take a look at your U joints, they can cause a screaming/howling noise if they go bad
mikajo39 is offline   Reply With Quote
Old 05-01-2009, 10:32 PM   #3
chas350
curious, did you replace the throw out and pilot bearings?
carrier bearing maybe?
does the sound change when you let off or step on it while cruising?
could be the rear, they can really howl.
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 05-01-2009, 10:38 PM   #4
powell72
powell72's Avatar
Since it goes away when you push the clutch in my first thought would be throwout bearing.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 05-01-2009, 10:57 PM   #5
Boog
laying low
Boog's Avatar
I'd be sure to drain the rear end and look the oil over real good. It probably needs changing anyway. Sounds from the rear end can travel up the driveshaft and sound like they're coming from somewhere else.
Can you put it up on jack stands and make it do this?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-01-2009, 11:09 PM   #6
Korr053
Yup we replaced the throwout and pilot bearings. (they were shot)
It still makes the noise when i let off but not as bad. And it gets worse the faster I go, but dosn't seem to make a difference if I romp on it at 55.
The driveshaft was tight going onto the tranny if that might make a difference I thought it should have had more play in it.
Ya I'm thinking we need to put the rear end off the ground and go over it from the tranny back to rear end.
Old 05-02-2009, 08:28 AM   #7
larry may
Is the clutch disc faced the right direction. as in is it flipped 180 degree. I sen this in a vehicle once.that resymbles the description you describe.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 05-02-2009, 04:15 PM   #8
Korr053
Thumbs up Re: Mystery drivetrain noise help!
OK!
We put the rearend up today and found the problem! The rear end is shot. I put a magnet in the rearend and got alot of metal, big nuggets. Thanks for all your ideas!
Old 05-02-2009, 06:04 PM   #9
69halfton
69halfton's Avatar
good to see you found your problem!
btw, welcome to the board!
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
