Old 05-02-2009, 11:03 AM   #1
Chuck78
Re: bed mount question - bent frame from towing?
I wonder if, after I replace the burb/panel bed mounts, use one of the thin 1/4" pickup rubber bed bushings and put it between the reinforcement strip cross sill and the frame?
Also, I suppose that I will most likely have to replace ALL of my body bushings when replacing the bed mount bushings, as on a panel/burb, I'm sure this would create problems.. bummer. One project always turns into ten!
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
