Re: bed mount question - bent frame from towing?
that is just meant to float so there is no sense to put anything there.
unfortunately with a pane or suburban body you should do all the mounts or it will give you alignment problems elsewhere. there is no easy way out with these things and then you are more than likely gooing to have to deal with some rust issues along the way ron |
are the front cab mounts on the panels/burbs also a specialty item, or will the standard pickup mounts work?
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc |
they are the std frt cab mounts but don't buy the p/u cab mounting kit as you will only be able to use half of it. buy the frt mounts seperately.. also replace you rad support mount insulators so as to align your frt end sheet metal to the body. everything is connected
ron |
