Old 05-04-2009, 04:00 PM   #1
matthufham
speedometer delete
i don't use it or drive it enough or fast enough to get pulled over, and my cable leaks at the tranny. is there a speedo delete cap i can buy somewhere and screw on the tranny?
matthufham is offline   Reply With Quote
Old 05-04-2009, 04:27 PM   #2
cdowns
cdowns's Avatar
Re: speedometer delete
no fluid is in speedo cable so your leak is from the tranny where the sending unit is//
Old 05-04-2009, 06:24 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Nope, there's no transmission speedometer delete... If you really just want to plug the hole, you could plug it with some sort of epoxy (after a good cleaning), find a wooden dowel that would fit in there sorta tight and tap it in place, or weld it shut...
But, if it were me, I'd just take the plastic driven gear, count the teeth, go over to the Chevy dealer and get a replacement along with a housing "O" ring seal. Maybe get the whole housing asm and the gear. I think I paid less than $20 for the whole thing last year. Napa may sell them also.
68gmsee is offline   Reply With Quote
Old 05-04-2009, 08:40 PM   #4
big mike71
big mike71's Avatar
Plug the cable in spread silicone around it then screw it back together it will stop leak.
big mike71 is offline   Reply With Quote
Old 05-04-2009, 10:24 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Matt,
I had the same problem...which tranny do you have....here's a thread from me...I have a TH400....http://67-72chevytrucks.com/vboard/s...d.php?t=333049
I'll also post up a thread for a TH350 (i think) for ya as well....http://67-72chevytrucks.com/vboard/s...d.php?t=331407
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-04-2009, 10:29 PM   #6
skchevota
skchevota's Avatar
If you really want it gone, remove the whole gear driven unit, and replace with a freeze plug. The 4x4s have a freeze pug in that hole from the factory because the spedo cable is driven off the transfer case on them.
skchevota is offline   Reply With Quote
Old 05-05-2009, 10:43 AM   #7
matthufham
freeze plug? what size do i ask for at the parts store? like for a ford 351 or chevy v6... or will they sell th350 freeze plugs? let me add i have a th350
Old 05-05-2009, 10:52 AM   #8
Sinister
Between Trucks...
Sinister's Avatar
Probaly just as cheap to fix it correctly.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-05-2009, 11:14 AM   #9
matthufham
i'm looking to clean up the dash, just need a fuel gauge and i can hide that and my oil volts and water, but i'm not sure how i'm going to do it. its a custom truck, not a daily driver.
Old 05-05-2009, 11:34 AM   #10
dan42
dan42's Avatar
I guess if you never sell the truck, it would be O.K. , but if are ever in a situation down the road where you want to sell, or have to sell the truck, that will be a huge minus for the buyer. Just a thought.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-05-2009, 01:04 PM   #11
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
how will you know when to change the oil????
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-06-2009, 10:43 AM   #12
matthufham
i dont drive it but 500 miles a year
