Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-05-2009, 11:05 AM   #1
71Dragtruck
71Dragtruck's Avatar
Re: Will intake still work
If your talking the 4 bolts in the center of the runners then yes you should be fine. Alot of larger single plane manifolds such as the Victor jr. don't have those holes and your aftermarket heads are likely set up for one of those manifolds. A better question would be are the heads too big for your application if your building a motor around a lower flowing intake (I assume because it has those bolts) and what about the cam and compression, can they support those heads?
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
