Mast. cylinder ID?
The PO installed a power booster and a master cylinder, but I don't know what kind/size it is. Is there anyway to determine the bore size? I need to install a new MC but don't know what size to get. Current setup is pitiful..
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug waltshow.com/Chevy |
![]() Join Date: Nov 2007
Re: Mast. cylinder ID?
Hey 66,
If you are running later model Chevy truck disc brakes you can use a later model master cylinder to match the brakes you are using. I used a 1987 unit. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
That looks like a drum/drum MC like the one I put in mine. Its for a '70 Impala. Not sure of the bore size though.
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
