Old 05-05-2009, 05:21 PM   #1
kcackler
Loud squeal on startup and sometimes while driving
Working on my little brother's 86 GMC sierra 3/4 ton truck and want to fix this last annoying issue before he moves up here.
When you start the truck up, 99% of the time, a VERY LOUD squeal happens. And it happens usually until the truck is warmed up. Even while you're driving, though, it will occasionally start back up.
The belts are new and tensioned properly. I've read that it could be the fan clutch. Is there any test I can do to confirm that it is or isn't? Just want to make sure before dropping 50 bucks on a new one.
Also, is the fan clutch something that can be easily replaced in under an hour or so?
Blue - 77 Chevy Scottsdale
kcackler is online now   Reply With Quote
Old 05-05-2009, 05:47 PM   #2
JohnC
JohnC's Avatar
Re: Loud squeal on startup and sometimes while driving
You may do a search on here. There was a thread talking about this a month or so ago. I'm not real familiar with the fan clutches so I can't give you much help there.
JohnC is offline   Reply With Quote
Old 05-06-2009, 02:40 AM   #3
AceX
>130dB Moderator
AceX's Avatar
Fan clutch is super easy to replace. I could probably do it in 20 minutes if I really go at it.
You can always grab a spacer from the local parts store for cheap, and use it to space the fan away form the pulley like the clutch would. If it still makes the noise, you know to look elsewhere.
Also, does the truck have A/C? The A/C belt is a PITA to tension properly, and it may also be a bad A/C compressor clutch.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 05-06-2009, 03:25 AM   #4
heavychevy79
Cheyenne Super
heavychevy79's Avatar
The belt is slipping on the alternator pulley, then goes away when the battery
voltage comes back up.
Take some sandpaper to the pulley and rough it up, and change the belt too if it looks badly glazed.
heavychevy79 is offline   Reply With Quote
Old 05-06-2009, 03:54 AM   #5
Lated
Lated's Avatar
Either that or the alternator bearing is going out. Mine made the same nasty noises when the bearing was going.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 05-06-2009, 09:01 AM   #6
truckincurt
also might be a power steering pump have you checked fluid level latley?
truckincurt is offline   Reply With Quote
Old 05-07-2009, 07:30 PM   #7
73chevyman
73chevyman's Avatar
most of the time a squeal is either altinator, and or aa locked up device such as altinator, ac compressor, and power steering. most of the time if you do not see any smoke it's a loose belt make sure your belts are tighten or not stretched if so replace good luck.
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 05-07-2009, 07:56 PM   #8
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
if it is anything like the video posted then yes it is the alternator. I replaced mine yesterday.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 05-07-2009, 10:28 PM   #9
88 Dippy
88 Dippy's Avatar
i get that same noise but only when i out it in reverse. and some times wile going down the road. it is varry odd
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
