Old 05-06-2009, 08:46 AM   #1
zork
2005 3/4 ton rear in 72 gmc
I.m thinking about putting a 2005 3/4 rear in my 72 gmc 4x4. I found one to match my dana 44 front rear. Has anyone done this? Will the spring perches have to be moved? Shock mounts?
zork is offline   Reply With Quote
Old 05-06-2009, 08:48 AM   #2
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
Re: 2005 3/4 ton rear in 72 gmc
The one i done all i had to do was move the perches, the shock mounts worked fine.
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 05-06-2009, 12:38 PM   #3
Zork!!....Howdy,long time no see.The perches are located wider and aren`t the shocks mounted wider,too?Either way,the later trucks have thr fore and aft shock mounting and the`72 is both forward.Still,yes,a very doeable solution to raising gearing.
