Old 03-21-2003, 11:10 PM   #1
UNCLEBOB
Four Wheel Disk Brake Master Cylinder
What master cylinder would I use on my 68 converted to four wheel disk brakes it has manual brakes. THANKS
68 lwb 383 solid roller,250dur, 582lift, afr 210s, 10.8 comp. edel.rpm, 750vs,1 3/4 headers turbo 400, 3500 stall,ford 9 inch 3.89 gears
UNCLEBOB is offline   Reply With Quote
Old 03-21-2003, 11:41 PM   #2
nu2-72
I have done some research into this.
The truck master for 71-72 is for front disc only and has a 7/8" bore.
Corvettes are factory four wheel disc and have a 1" bore.
I plan to use one from a 1976 Corvette that I have left over from a restoration. I will also use the Vette prop valve.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 03-21-2003, 11:55 PM   #3
Mike C
Mike C's Avatar
The 'vette master was going to be my suggestion as well, but another good one is a 79-81 WS6 TransAM that had factory rear discs. It might be more inline with your needs depending on what calipers you have.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-22-2003, 12:14 AM   #4
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
on black72"s truck, he used a master clyinder, and booster off of about a 90 chevy truck,I believe, and the disk brake rear end he used was out of a caprice cop car, and he used the prop valve from it also, seems to work great, these are junk yard parts, and sound alot cheaper than anything that says corvette...lots of luck
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 03-22-2003, 01:20 AM   #5
UNCLEBOB
The trans am has a 1 1/8 bore. decisions decisions?
Old 03-25-2003, 04:39 AM   #6
nate68
i use a 76 vette master, works great
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 03-25-2003, 10:19 AM   #7
Frank_Zeller
Frank_Zeller's Avatar
Find a master with 1 inch or less bore. The 81 TA uses the newer style aluminum master that is 25mm bore. Brake proportioning valve from a 1977-1978 Seville with 4-wheel disc. The newer style masters have the lines reverse. Brake vacuum booster from 1983-1987 Regal/Cutlass works with the newer style masters and bolts to our trucks. I have all this stuff but have yet to take on the conversion.
Good place to look up master cylinder bore diameter
www.partsamerica.com
good info here
http://home.pacbell.net/bigiron/Arti...rRearDisc.html
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 03-25-2003, 11:12 AM   #8
Mike C
Mike C's Avatar
Thanks for those links Frank. They do not show a 302 powered 69 Camaro to look up the disc/drum Z/28 master. They show two different Corvette masters, a 1 1/8" for power brakes and a 1" for manual brakes.
For the 80 Trans Am, they show a 1" bore for manual brakes. Not sure on the depth of pushrod hole on power vs. manual mc, but on my '69 Camaro I have a Z/28 power disc master actuated manually with no problems, so there appears to be several options.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-25-2003, 03:31 PM   #9
dmec
dmec's Avatar
the trans am master is the same as cad seville. both are for power brakes. corvette is the only manual disc master i know of.
dmec is offline   Reply With Quote
Old 03-25-2003, 05:57 PM   #10
Mike C
Mike C's Avatar
Like I said, if you go to partsamerica.com and look at a 1980 firebird 4 wheel disc, it shows a 1" bore master for manual.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-26-2003, 12:09 AM   #11
blazunfool
The one I am using on my 4wheel disc conversion is off a 77-79 caddy seville. Those cars had 4 wheel disc brakes and the reserviors are the same size front and rear. Also it seems to have the same mounting and piston depth as the one on the truck with power brakes and disc/drum.
72 2wd Blazer 305TBI/700r4., 69 C10 SWB 400SB TPI, 400trans, Step side ., 72 4WD Blazer 350 TBI, 350 serp. drive & "Old Air" ., 94 Camaro Z28 LT1., 94 Grand Cherokee V8, 95 Grand Cherokee 6cyl.
blazunfool is offline   Reply With Quote
Old 03-26-2003, 01:02 AM   #12
Low69CST
I talked to the guys at ECE, they used the stock truck booster and mastercylinder and said it worked fine.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
