05-05-2009, 01:54 PM | #1 |
driveline questions
i want to put a 700r4 in my truck i am hoping to get 650 hp w nitrous. do i need lock up or non lock up. who make manual valvebodies for them? will i still have to have a tv cable since i will be running a manual valvebody? or should i just build th350 to handle it. also will ece 5 lug conversion axles, auburn locker and richmond 4.10 with c clips handle this much power? or will i need to get c clip eliminators and custom alloy axles? who makes alloy axles for 68 12 bolt in 5x5 pattern? any help would be appreciate.
05-05-2009, 02:02 PM | #2 |
Re: driveline questions
o and will be making 450-500hp on motor and 100-150 shot. no slicks mainly street use. harldly use nitrous if any.
05-05-2009, 03:17 PM | #3 |
Look into the Turbo 700 kit. It's from Premier or Prestige, or something like that.
05-05-2009, 04:06 PM | #4 |
At 542hp to the crank in my motor I went with a fully built th350, I have a 12bolt with stock axles 373 gears. I did not go with a manual body because I did not want the hastle of shifting as I mainly wanted a street vehicle with some hump..If I decide to start running slicks or what not then I will do mini tubs and have a ford nine inch four link set up.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-05-2009, 04:27 PM | #5 |
hey big al are you running an
05-05-2009, 04:28 PM | #6 |
hey big al are u running an aftermarket posi? and im guessing ur still using c clips
05-05-2009, 04:35 PM | #7 |
anybody got any info on that kit i cant find it also does any body have any more info
05-05-2009, 05:08 PM | #8 |
How about this? http://www.700r4l60e.com/store/catal...1993-p-41.html
I'll try to find info on that other kit. |
05-05-2009, 05:22 PM | #9 | |
Yes I have the c-clips, 373's and an eaton posi unit.....
05-05-2009, 10:40 PM | #10 |
do after maket posi units have openings for c clips?
05-07-2009, 12:33 AM | #11 |
Professional Grade
Try this site, I have used them, good prices, solid tranny, can make it manual valve body or whatever you like. http://www.outlawtransmissions.com/SearchResults.asp
Heavyest you can build a 700r4 shipped to you with a converter and no core for $1375 seems allright to me.
61 GMC 9' Step Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828 67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531 71 GMC Street performer in the works Waiting for warm weather http://67-72chevytrucks.com/vboard/s...d.php?t=341946 1990 GMC Sierra GT-sold 1983 chevy 4x4-project on hold maybe sell 1969 Triuph GT 6- sold 1996 Ford I-6 5 Speed 4x4 2004 Dodge Intrepid- milage maker 1959 Ford Fairlaine, factory a/c 292Yblock- sold 1982 Honda XL500R Always lookin for other old trucks! |
