I have a 67 with a real rusty gas tank in it. So rusty that the truck won't start. When I replace the tank should I also replace the fuel pump also? Can the fuel pump be cleaned? Thanks
If your not living for something, your dieing for nothing... |
![]() Join Date: Feb 2002
Re: Should I replace the fuel pump when replacing gas tank???
Replacing the fuel pump is easy and cheap. Also good insurance. Some early models could be refurbished, but I've found that the kit is more expensive than a newer style, toss-when-done type. Don't forget an inline gas filter between the pump and the carb.
This is assuming you have the stock mechanical fuel pump. The electrics [like the Holley Red] are cheaper to rebuild than replace.
I have an inline gas filter now right after the fuel pump and its got some sediment in it but not that bad. I will replace the tank and sending unit to be 100% sure the gas is clean. Is it possible the sending unit is rusted so bad the gas can't get through?
Retired Air Force Veteran
![]() Join Date: Aug 2007
The sending unit could also be an issue. As OrangeSunshine said, changing the fuel pump is easy and not to expensive and as he suggests, be sure to change that fuel filter. My tank was pretty bad also. There are a couple of ways you can actually clean your tank. I used dawn dish detergent and flushed my tank with lots of water and let it dry as a DIY clean but then bought it to a local radiator shop and had it boiled clean and coated (bout' $80 bucks in my town). As far as the Sending Unit, I purchased a new one from Brothers. Again, it was inexpensive. Bout' $40 bucks. Do you self a favor, change all that stuff. Your engine will love you for it. Good Luck!
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
It would be foolish not to change it while the tank isbeing changed.
papawswrench Certified wrench hound ! Tool Talk Randomview PapawsImages https://www.flickr.com/photos/nhankamer/ |
also try blowing out the fuel lines as well as replacing the rubber sections especially the one under the cab is good insurance
Will do. I am going to have the tank boiled and coated, change the sending unit, new fuel pump, new filter and replace rubber lines. I am so stoked now. Thanks
#8 | |
Foreign Object Debris = Foreign Object Damage. Your goal is Zero Defects, thru zero FOD. The sock on the end of the fuel pickup can decay and not flow thru gas.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-07-2009 at 05:46 AM. |
since we are on the topic of dirty tanks, I dumped a bunch of, ( as best as I can describe), looks like little chocolate sprinkles, out of my filter. Does anyone now what it is and causes it
Are you sure it was not rust sediment?
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 05-07-2009 at 08:08 PM. |
I cant tell what it is, as stupid as it sounds, small black choclate sprinkles is the best way I can describe it, any ideas on the best way (and easiest of couse) way to get rid of it
Chocolate sprinkles?? Maybe bake some cup cakes???
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
dont like to bake so jsut ate them raw
