how wide of a tire will fit
How wide of a tire will fit on a stock width rear end, before it rubs the leaf springs in the stock position but still fit inside the box wall (I will probably cut the stock wheel wells out)?
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
Re: how wide of a tire will fit
I don't know about a leaf truck but if you swap to trailing arms you can fit a huge tire. I had a 71 with no mods to the wheel wells and had 28x12.5 sportsman pro m/t's on it with a 10 inch wheel.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Ready to go fast!!
i have the same question!!! what tire would fit with trailin arms and cut out wheel wells?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
29x14.5/15 Hoosier Quicktime Pros on a 15x12" rim with 7.5" backspace will fit trailing arms and cut fenderwells, stock rearend.
http://67-72chevytrucks.com/vboard/s...d.php?t=276897 here is a old pic of my truck with this combo. Narrowed rear I now run a 31x16.5" Mickey ET Street with lot's of room.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 05-07-2009 at 10:24 PM. |
Here's a pic of the new tires.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
I have M/T 29x15R15 with 6.5 inch backspace, fits fine with about 1 inch from leaf spring.
The pic in my signature is old and without the new tires. Last edited by Nolowrider; 05-07-2009 at 11:45 PM. |
What kind of tubular control arms are those?
I can't remember for sure, thinking they are CPP if my memory is right, I bought them from a board member that went with air bags instead.
Machinist
A friend of mine has 29 18.5 MT under his ...... its so close but there under there
| Bookmarks |
