I took the carb off my truck to clean it thinking it was dirty when in fact it was fine, but I tore the gasket and have to replace it. Does anyone know the torque settings on the 4 bolts when I bolt the carb back on. I have an Edelbrock Performer aluminum intake and a 600 Performer carb. I just don't want to mess anything up. I think its between 25 and 30?? Anyone?
If your not living for something, your dieing for nothing... |
Re: Edelbrock carb to manifold torque setting?
Does no answer mean everyone is still running Rochester 1 or 2 barrel carbs or was my question just really stupid? LOL
i have the same setup, but i suck at anything engine related. sorry
1972 longbed- 454 1967 shortbed- 355 |
Thanks anyways. Hey, what are you running for a fuel pump on your set up? I have to replace mine and I think it will just be a stock pump for a 1970.
Just a little more than snug. Check them after a week or so.
The service manual says 14 ft lbs. I always do the "little more than snug" thing though.
99.9% of all carbs i've worked on it's about imposible to get a torque wrench on them so i just go snug
I've never torqued a carb down and have always been fine with no leaks.
-Scott- |
They say about 10-15 ft. lbs, no more no less
My experience is that when you go into aluminum, you shouldn't do anything over 15lbs. Make sure to use some anti-sieze, too.
