#351 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Re: project INCREDIBLE HULK 6.2L with 6L80E
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#352 |
bit more progress, i got the door fitting the best it could.....the gaps sucked (aftermarket door), expecially around the window frame.....it was too tight on the upper aft part of the window opening, then it tappered to about a 1/4" gap in the middle, and then went to about a 1/32" at the upper front.......what i had to do was cut the door at the front door piller, then remove 1/8" of material, pull the front frame back....that took care of the front piller gap....on the rest of the window frame i pushed the rear of the window frame forward, then shaves off about 1/16" to get the gaps good......
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 68 short step; 03-16-2009 at 11:45 PM. |
#353 |
69fatmotor
don ,
the truck is looking great . are you going to weld the seem across the back of the roof ? what's the color gonna be ? well , keep up the great work , can't wait to see it finished. i'm sure the owner ![]() |
#354 | |
![]() as for the color, its still to be determend.... |
#355 |
here is a bit of an update....
got the rear step notch installed, (the old c-notch wasnt doing it for us) so with the step notch we were able to lower it about 2" more..... here is some pics, the shocks will be added shortly, when the bridge goes in..... also keep in mind that the tires on there now (rear) are for rollers only, they are 31".... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 68 short step; 03-29-2009 at 08:42 PM. |
#356 |
#357 |
![]() Join Date: Apr 2005
That's starting to look like a truck!!!!! When's the projected completion date?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#358 |
got a bit of an update.....
im back on the dash/center console....i got the side peices made......the center console is kinda challenging (because i wanted to make it out of 1 peice), so instead of making it out of 1 peice, its gonna be 4 peices welded together....here are the side peices, they have a rolled top (kinda see this in the pics), and also im gonna make a inner structure to support the weight of our electronics, arm rest, and just general wear and tear it'll receive..... also here is the side profile of how the truck sits now with 30" tires rear and 27.5" tires on the front (both on 15" wheels)....... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#359 |
#360 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I take it the garage was getting too smalll...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#361 |
need more photos of the tool ben lol...thought it was goin in the kitchen?
R.I.P. Killer 71 10/26/07 |
#362 | |
yelp, i had to make a move, when i started takeing up family members garage space
![]() Quote:
![]() the specs are 72" wide 30" deep and 45" tall.....its a big-unnn |
#363 |
Hey..... Those bedsides look might familiar
#364 |
That's some nice work!
#365 |
Under Construction
looking good.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#366 |
how much would that dash center console run me if u made me one similar to it
1968 CHEVY C10 THE NEVER ENDING PROJECT
#367 |
#368 |
I am so jealous of your ride height, mine will be 2 inches taller than i had hoped for, guess bags will come into play later, btw that console is just plain Sexy.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#369 |
#370 |
#371 |
You will always need more room. We sold our old house to buy this one with a 1200 sq. ft shop, plenty of parking and a 2 story out building and now we are out of space. Luckily I am zoned commercial so I can put a second story on the shop for almost 2400 sq. ft. Not bad for being right down town. Next stop will be 5+ acres!
Truck is looking great by the way. I like the dash you have designed. I should have my Lazze English wheel real soon so I can start playing as well. Kevin LFD Inc. |
#372 |
got the center console made....the front peices were the last peices to be made, so i made a cardboard templete, transfered it to metal, cut and fit, added a stiffner for some rigitity, then welded together. .....ill add some stiffners that connect the two sides, when the dash comes back out.... here are the pics (the 3rd one looks like some mid-evil deheading device)
#373 |
and the other side
#374 |
and it fitted in,
#375 |
Village Idiot....
Looks great! Are you going to make any provisions for carpet or leather to go under the console or are you going to bind the carpet at the edge?....sorry I'm in interior mode right now and it looks like the console fits nice and flush with the floor...
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
