Lift options for A 67 C20?
ok all,
What are the options for lifting my 3/4 ton 4-6"? Thanks all! |
Re: Lift options for A 67 C20?
The best solution I have found is SKYJACKER. They have lifts from 2, 4, 6, 8 inches and they have three levels. one has an add a leaf with blocks, one is a step up from that and the last level is four new leaf springs and u bolts bushings, etc. It seems like they have a great kit and their softride springs are supposed to ride very nice. Here is a link to a truck that has the lift...
http://www.truckinweb.com/features/0...k10/index.html here is a link to their website... http://www.skyjacker.com/products/pr..._submodel=BASE There are others like superlift and cst, but after my research and hearing other people talk, it seems like skyjacker is the way to go. Retail is 1300 for the 8" lift but i have found it for 1050. 4wheelparts seems to have the best prices. You can buy it with or without shocks. And thats all I know. |
Thanks 71,
But I could have swarn I was reading here that the 67 has issues with springs from 68-72 kits? Is that not the case? |
Page intentionally left blank.
![]() Join Date: Jul 2006
If you want to do an all spring lift and not rear blocks, then yes, there are issues. The front springs will work from the kits, but the '67 springs are unique. The length, width and pin position are all different from the '69-72's. If you want to stay simple you're looking at either doing a shackle flip form ORD or DIY4x, or custom springs. I think the flip is the option most take, it gains about 4" itself, and you can go with longer shackles to get higher, though I don't know what the limit is to that. I did a flip from DIY4x, Kert was easy to work with, and is familiar with the spacers needed to mate the bracket and springs. If you check through some of my older posts, there are pics of the setup. Hopes this helps!
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams '67 GMC 4x4, 305 V6! Or all the parts for anyway... '17 Subaru Outback. '18 Toyota Tacoma TRD Off Road. '99 Ducati 900SS. |
I did an add-a-leaf to my 68 and gained 1.5", that comined with the rear shackle flip would get you close. Or take your rear springs to a spring shop and have them rearched, or another set made.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#6 | |
Thanks for the DYI info. It looks like a more sturdy design. Last edited by Hallz; 05-05-2009 at 02:54 PM. |
Dually Pride
A C-20 is 2wd, are you talking about a 4wd?
i dont mean to be a dink, just got confused lol
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
K-10 or K-20 for a 4wd
Dually Pride
yeah that would be a K-20
we all gotta learn sometime!
I will be curious to see what you do, I also have a 1967 K20 Longbed!
1967 K20 Stepside Longbed 250-6 sm420 |
