Old 05-10-2009, 06:58 PM   #1
k-nuts
k-nuts's Avatar
Jimmy as my DD
So the A/C has been out in my DD Silverado since the end of last summer. I finally got fed up and took in and had it all redone. Shop said it would be 2-3 days so I decided instead of renting/borrowing a vehicle, I'd just take the Jimmy to work. I've had the Jimmy about 3 years and have driven it only a handful of times around the block. for the most part it has sat awaiting restoration in my garage.
So I gave it a good once over. Found only one bolt of the 3 on the torque converter.
Then charged the battery, replaced the alternator, fuel filter & rubber lines, PCV valve, checked the brake fluid level, radiator, and tires. It fired right up. (I had already replaced the fuel pump and starter the week I got the truck). No reverse, so I pushed it out of the garage. Checked tranny fluid and it was LOW. Added 2 1/2 quarts before it even registered, then topped it off. Shifted perfect.
So 3 days, topless, 96* and humid all three days. Over 100 miles a day. I work out of my truck and its 30 miles each way not including the constant start/stop of checking my jobs all day. Ran perfect the whole time!!
Even the "hot start" problems were minimal. Pee'd a little antifreeze at the beginning from the hose @ the cap, but then nothing. So probably a little overfull?
Anyways just rambling and thought I'd share. Of course now it's almost too hot already to go topless!!! But I need to be driving this more (just not to work) Sure was nice to get the silverado back with COLD A/C!
Here's a pic of the Jimmy at an old gas station.
k-nuts is offline   Reply With Quote
Old 05-10-2009, 07:45 PM   #2
nbrfd007
nbrfd007's Avatar
Re: Jimmy as my DD
Everything better topless! Your Jimmy looks great.
nbrfd007 is offline   Reply With Quote
Old 05-10-2009, 10:42 PM   #3
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Jimmy as my DD
Dude, I'm so jealous. The jimmy looks great. Now that yours runs great you'll have to come down to S.A. to visit. Glad to see you are driving it more. Later dude. Mario
BLUE THUNDER is offline   Reply With Quote
Old 05-11-2009, 12:50 AM   #4
k-nuts
k-nuts's Avatar
Re: Jimmy as my DD
Looks better in the pictures but thanks. Found one of my front shocks lost a lower bolt too. I thought it felt a little bouncey. Yeah Mario, I took your advice, since I'm not working on it, drive it.
Old 05-11-2009, 11:10 AM   #5
Yukon Jack
Yukon Jack's Avatar
Re: Jimmy as my DD
Glad you're enjoying it - that's what they are for!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-11-2009, 12:16 PM   #6
1949gmc
Re: Jimmy as my DD
I am sooo jealous... it's 55 in No. Illinois right now.
1949gmc is offline   Reply With Quote
Old 05-11-2009, 02:39 PM   #7
lgdpt
lgdpt's Avatar
Re: Jimmy as my DD
The more I driver mine....the better it runs. Much better than the alternative.
lgdpt is offline   Reply With Quote
Old 05-11-2009, 08:47 PM   #8
turp mcspray
turp mcspray's Avatar
Re: Jimmy as my DD
Cool picture at the station!
turp mcspray is offline   Reply With Quote
Old 05-12-2009, 01:04 PM   #9
Thealien
Thealien's Avatar
Re: Jimmy as my DD
Nice picture, use it more.
Old 05-12-2009, 01:42 PM   #10
OARNGESI
OARNGESI's Avatar
Re: Jimmy as my DD
Nice jimmy
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 05-12-2009, 10:00 PM   #11
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Jimmy as my DD
Sweet Jimmy!!
My dmax has been in the body shop all week, so I've been using my '69 and topless '70 for my DD
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
