max backspacing:whos got the most dish?
Im kicking around the idea of stuffing Vintage Wheelworks
V48s under my '73 C10. 17x9 front and 17x11 in the rear. how much backspacing should i run? I'd like to have about 3/4 inch between the tire and fenders. i'd measure it for myself, but i'm stuck in my office daydreaming about this and the truck is at the shop. has anyone here run really wide wheels? got pics? thanks for the help. -mike
-mike |
Re: max backspacing:whos got the most dish?
How low is it? Mine is dropped about 8" in back (flip-kit on 8-leaf spring pack + Bell Tech shackles). I ran 10" wheels w/5.00"BS & was about .750" from the inner tub wall & .500" from the outer lip.
I can't see 11's fitting on a low truck w/o mini-tubbing. They might fit, but definitely would be TIGHT. Even then, your initial question reads "whos got the most dish?". Rear end width plays a big part on the back-spacing required for that deep dish look. My 74's 12-bolt is stock length so that previously mentioned 5.00" BS is about neutral; 4.00" BS would have more dish but interfere sooner w/the outer fender-lip. 4.00" BS on an 11" wheel would look deeeeeeep but the rear housing is going to need to be narrowed. Board-member 'Crawdadfox' has a narrowed rear end on his '77 & runs 10" wheels w/4.00" BS (22x10's). His wheels look killer w/the deeper dish vs. mine but the added expense has to be considered (unless you've got connections for that sort of stuff). Look up the thread on his "ebay 77 w/Porterbuilt F/R Dropmembers" to get an idea on the deep dish.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-11-2009 at 08:07 PM. |
>130dB Moderator
Dammit Scoti! I was getting all excited about running a 20x12 someday and you just killed it for me...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
#4 | |
It'd be alot cooler if you did
I'm running a 20x10 with 5.25 backspacing. I would say my tires are less than an inch from the inside of the wheel wells. I would not recommend anymore dish to be safe.
![]() Last edited by smashingchuck; 05-12-2009 at 10:51 AM. |
whoops. my bad. i meant most dish, least backspacing.
with an 11 inch wheel, when does the wheel tub become an issue. thanks.
-mike |
See the post above yours.....
I have car A.D.D.
That truck looks mean! And the rear wheel lip looks perfect with it.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 05-12-2009 at 02:51 PM. |
>130dB Moderator
My suspension won't get in my way? I thought that that was going to be the bigger hurdle...
Leaf springs will depending on how deep but 17x11's shouldn't be an issue. 20x12's would take some investigating to verfiy.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-12-2009 at 03:34 PM. |
I run 15x10 rims with 3.75 inch backspacing and 325/50/15 drag radials in the rear. Basically even with the fender lip and gives a really mean look for the track. Probably won't work with this tire for a lowered truck but maybe with 295/50/15. There's plenty of room to run more backspacing but this was the only backspacing offered for this wheel and I wanted these to match my 15x8's that I use for street driving.
Pics at the end of this thread: http://67-72chevytrucks.com/vboard/s...=320246&page=2
1977 GMC Sierra Grande Last edited by Pyrotechnic; 05-12-2009 at 03:58 PM. |
>130dB Moderator
Looks like I have some measuring to do later.
Guess it doesn't really help the the wheel I want doesn't actually come in a 20x12...
#13 | |
![]() Join Date: Aug 2008
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Down......with the sickness!! |
>130dB Moderator
We all miss the one that we let go...
On topic, that rear wheel set-up looks about what I want...
#15 | |
#16 | |
-mike |
#17 |
Read this thread, it has alot of good info and a sweet ride to look at.
http://67-72chevytrucks.com/vboard/s...d.php?t=317834 |
