Old 05-12-2009, 07:54 PM   #1
hwyix
How good is 67-72 burb for towing?
I original wanted the 2dr jimmy/blazer, but I searched over there and many people thought the truck was too small to be a good tow car.
Is the 67-72 suburban big enough, strong enough? I know I can upgrade the engine/transmission & brakes to handle anything but is the rest of the truck up to it? I forgot to add this for towing a 3500lb car plus open trailer. I would like to buy an enclosed trailer some day though.
One more question, for you people who lower and c-notch the rear of your truck. Is the frame still just as strong for towing? Or is that something I should just forget about if I plan to tow?
thanks.
hwyix is offline   Reply With Quote
Old 05-13-2009, 08:18 AM   #2
4oldcars
4oldcars's Avatar
Re: How good is 67-72 burb for towing?
Mines lowered (springs changed) and I tow a car hauler. Sway bars make it work.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 05-15-2009, 08:16 AM   #3
68396
A Blazer has a short wheelbase which I've found was poor for towing. The Suburban has become a classic towing vehicle. Countless amounts of Airstream and other RV trailers have been towed all over the country behind a Sub. My father bought his 1968 Sub and an anti-sway hitch to tow a trailer.
68396 is offline   Reply With Quote
Old 05-15-2009, 09:07 PM   #4
jmbstudios
Pickin' and a Grinin'
jmbstudios's Avatar
I have often wondered this.. I have a 3/4 ton Suburban 3 speed. How do you think that thing would hold up?
My Trailer dry weight is only 4200 lbs. The thing I would worry about is brakes. I guess I would really need to have them checked.
I would figure the 3/4 ton should be fine, the 350 motor is strong, but how would the 3 speed do????
I would be hauling it from Arizona to San Diego. 4 hour trip.
jmbstudios is offline   Reply With Quote
Old 05-16-2009, 09:13 PM   #5
capev86
they are awesome tow rigs. a blazer can haul a trailer just fine, but the longer wheelbase is preferable.
it is mostly dependent on engine, trans and gearing. contrary to what they tell you, a manual trans is perfectly fine for heavy towing (the 3spd saginaw is a rugged unit after all). the problem is many people are not competent enough with a manual to work it properly without excessively slipping the clutch, etc. an automatic is certainly easier for regular trailering duties.
my suburban will be a tow vehicle really soon. the 3/4 ton chassis and bigger brakes will be great assets, but a 1/2 ton truck works good too (3/4 ton rear springs and disc front brakes are a good idea for a heavy trailer). on my truck i will be installing big sway bars (1-1/4" front, hellwig 1-1/8" rear) and using a trailer brake controller. i strongly suggest sway bars both front and rear....my truck is kinda wobbly even with 3/4 ton springs. sway bars give more predictable handling and will help control the trailer.
other suggestions would be to keep up with proper maintenance and if you want the best (like me) switch out all fluids for synthetic, especially automatic transmissions as they generate even more excess heat when towing. aux trans and engine oil coolers are added insurance.
my suburban is a '72 2wd 3/4 ton w/ a 307 w/ 3spd manual on the column and i believe a 4.57 rear gear. my dad had a '72 1/2 ton 2wd w/ 350 and 3spd auto and we hauled our '71 holiday 23 footer with it (still have the camper). my dad changed it out with a 305 with an rv camshaft, 3/4 ton coils in the rear, dual exhaust and an aux trans cooler and it hauled that 6,000 pound camper all over the place.
the other issue is that fuel injection is a good idea if you do a lot of traveling with a camper......high altitudes tax carbed engines that are tuned for use on the coast. my family discovered this when we used our '84 suburban with a transplanted 406sbc to haul the holiday out west through the rockies and grand tetons. we were going 6mph up a steep grade on our way to see mount rushmore. good luck to all you suburban nuts hauling campers!!!
capev86 is offline   Reply With Quote
Old 05-20-2009, 01:49 AM   #6
hwyix
Thanks guys for all the advice.
The blazer is really the more perfect size truck for the other 99% of the time that I would not be towing my car to the track. Do you think a blazer is big enough/strong to tow 8000lbs ( just a guess, 3200 car, trailer, tools, tires)?
I mean I already know my little 1999 supercharged 4runner can tow the trailer & car, but it was not fun. Around 65mph then a bump or some wind I was all white knuckles. Maybe it was just because it was a u haul trailer or maybe it was because the 4runner is kind of high for such a short wheel base car.
I know with money I can put what ever motor/transmission/brakes into the truck, but I can not change the wheelbase or track width.
Do you any of you guys have your frames c-notched? Seems like if you where towing something you would always be pulling at the weakest link on the frame there.
Old 05-20-2009, 04:47 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I'm thinking of rebuilding my '67 K/10 Suburban with a 454/TH700R4 to tow a 20' 1978 Argosy [by Airstream]. I currently have a '71 Jimmy K/5 for a tow rig, but I havn't had much chance to run with it. as I'm still working on the plumbing and electrical systems.
Old 05-20-2009, 05:42 AM   #8
prairewolf
My Subs previous owner was said to be an organizer for Peninsula Motor Club,(Air Stream I believe) the Sub has the sticker on bumper, large dealer added Travel Tank, and trans cooler in front of radiator. it still had CB radio antenna whip knob on it and heavy duty hitch when I baught it. so back in the day they were more than capable. 3/4 ton.
Any towing has a lot to do with the driver also, ... a lot of capable vehicles end up in the ditch.
life is good,kent
eat,work,spend,sleep,repeat.
prairewolf is offline   Reply With Quote
Old 05-20-2009, 07:40 AM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
5.7 throttle body and 700R4...works great!! For sale by the way!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 05-20-2009, 09:44 AM   #10
Skirkpat
Skirkpat's Avatar
You can drive your truck with your feet, It is about as stupid as using a short wheel base tow vehicle, Ask me how I know? Never mind, I will just show you:
Imagine a nice 16 foot tandem axle trailer upside down on a nice 1978 Z-28 in the middle of the highway, with a Short wheel base truck hanging from the safety "CHAIN", then ask yourself it you would like to experience it, and please do not say that it can't happen, It does.
Skirkpat is offline   Reply With Quote
Old 05-20-2009, 11:22 AM   #11
IAFF2407
IAFF2407's Avatar
can someone post a pic of a sway bar on the rear, coils.
thx,
Al.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 05-20-2009, 06:13 PM   #12
hwyix
You have two trucks that look great. Too bad your 2,612 miles away instead of 50.
Old 05-20-2009, 07:30 PM   #13
Hart_Rod
Hart_Rod's Avatar
thx,
Al.
Sway bar pictures......
Hart_Rod is offline   Reply With Quote
Old 05-20-2009, 07:34 PM   #14
72freak
72freak's Avatar
Pick one...Ill split the shipping with you.
Old 05-21-2009, 01:55 AM   #15
IAFF2407
IAFF2407's Avatar
thx for the pixc's Rob, where did you get yours? ist it 1" or is it more.
Al.
1972 GMC Sierra
Old 05-21-2009, 11:02 AM   #16
Frizzle Fry
Frizzle Fry's Avatar
Another rear sway option
Frizzle Fry is offline   Reply With Quote
