Old 03-22-2003, 07:56 PM   #1
lotik
drag it like you stole it
hood release spring?
is there a such thing for these trucks? my hood is in desperate need of one. but the trucks i have seen dont have one.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 03-22-2003, 09:32 PM   #2
72MARIO
72MARIO's Avatar
Not from the factory. you could get a spring from a 73 -87 truck and make it fit Should be pretty easy conidering the work you have done so far !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-22-2003, 09:59 PM   #3
lotik
i just seems like there should be since there are two bolt holes on both sides of the hood pin catch
Old 03-22-2003, 11:00 PM   #4
RON WOODGEARD
Resident Young Old Dude !
I have wondered the same thing, I have to take a screwdriver to get mine opened, Real bummer.. I'll have to try the 73 up idea.
Ron
RON WOODGEARD is offline   Reply With Quote
Old 03-23-2003, 01:04 AM   #5
orange72
orange72's Avatar
mine pops up when i pull the latch.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 03-23-2003, 03:05 PM   #6
72MARIO
72MARIO's Avatar
There is a piece that bolts in thoes holes your talking about it bolts to the bottom of the rad support (or cradel ) and to 2 spots on the grill. The hole in the grill has a nut on the bottom the next hole in closer to the firewall it does not have a nut at the bottom that nut is on the grill support If you need more help send me a pm. Mario
2005 TAHOE DD
Old 03-23-2003, 07:22 PM   #7
72MARIO
72MARIO's Avatar
Here you go have a look at the piece behing the grill. you need it to keep the grill stabel. the grill will get tougher too.
2005 TAHOE DD
Old 03-23-2003, 07:29 PM   #8
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
I have one of thoe if anyone needs it, very clean $20 to your door, O.B.O
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 03-23-2003, 08:46 PM   #9
Johns70
Johns70's Avatar
that large hood pin in the hood needs adjusted up or down to get the hood to pop up when you pull the latch. you shouldn't need a spring to pop it up,its built into the latch assembly.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 03-23-2003, 09:05 PM   #10
KWinBigE
I had the same question.
Good tip Johns.
KW
71 Custom 10, LWB
RED, RED, RED
KWinBigE is offline   Reply With Quote
