Location of 7-72 mirrors???
Ok I got a set of 70-72 outside mirrors for the burb yesturday at the show. I was wondering how to correctly locate and drill the holes from them? Does anyone have a measurement from somewhere on the door? Or do I just guess?
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
I would think the ideal place to put them is where you can see the best behind you and leave room for the vent windows to operate
Thats the Hillbilly way
Which mirror did you get I can show you these on my truck I put them on using the Assembly manuel.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
other side
Not positive, but if you check inside the door some had the correct spots..............
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Dreaminator
My 71 had a small knockout like piece that you could feel up under the inner panel. I mounted mine based on line of sight and being able to open side vent. Kinda wondered which way to rotate the mirror though. The mirror is off center on the post.
The Dreaminator Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400. |
Use the gasket (left for left side, right for right side) as a template, center on flat area and measure 6 1/8" from door edge to gasket for left side. On right side, the measurement is 8" from the door edge to the gasket. Mark you holes and drill 11/32 diameter holes, in the three hole locations. I use stainless steel screws for installation.
If you measure a truck that had factory mirrors, you can confirm my dimensions. The assembly manual references some datum points that are used for their dimensions and I haven't been able to determine where they are located from. I suspect they are referenced to a common location, but they are not evident. Jim Last edited by JimKshortstep4x4; 03-23-2003 at 08:45 PM. |
