Old 05-14-2009, 05:42 PM   #1
romarti0825
romarti0825's Avatar
Question About Rear Blazer Seat?
I'm putting my '70 Blazer back together and I was wondering if anybody knows or has a picture of the spacing between the rear brackets? While I was looking at the floor of my Blazer, the pre-set holes look awfully close together compared to the rear brackets of the seat I have bought for it.
'72 Cheyene short fleet.
'70 2wd Blazer
romarti0825 is offline   Reply With Quote
Old 05-14-2009, 06:35 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Question About Rear Blazer Seat?
Older pic, but maybe you get the idea
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-14-2009, 06:57 PM   #3
romarti0825
Ohhh.... Okay thanks. Do you happen to know what size bolts to use to mount brackets to seat and also what size bolt to use to mount to floor?
'70 2wd Blazer
Old 05-14-2009, 10:54 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Seat has never been in it since I owned it, sorry
Old 05-14-2009, 11:55 PM   #5
13lazer
13lazers' blazers
13lazer's Avatar
you should have a piece of flat bar that runs across with threaded holes under your bed. the bolts are oddballs because of the seatbelt. there is a long shank so that the seatbelt can move around. if i remember correctly they are fine threads. they aren't easy to find. i got lucky and got a bunch of o.e. hardware from a buddy of mine that parted these old trucks out and sold them at the swapmeet.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 05-15-2009, 02:16 AM   #6
woodymm3
woodymm3's Avatar
the rear seat that you most likely have, came out of a 73-78 blazer. i ran into the same problem the way to tell is the front brackets.... if you have the tube bars on the front you have the corect seat and should try to find some hold downs... if you have the 73-78 though you will only have two brackets in the rear.
woodymm3 is offline   Reply With Quote
