Old 05-15-2009, 11:52 AM   #1
71C10SWB
71C10SWB's Avatar
Question Lot's of popping and cracking on deceleration...
I've got my '71 swb back on the road and I like everything except all the noise it makes when I'm decelerating.
I get a lot of cackling, popping and backfiring, especially going down a big hill.
Before I give you the set-up, I want to say, I didn't set this up.
It has:
350, Powerglide, 6-cylinder gears, hooker headers, single plane Weiand intake (high rise), Edelbrock carb (cfm unknown), glass packs and full length 2.5" exhuast.
Is it the glass-packs, the engine set-up or just the nature of the beast?
What would help? Turbo mufflers? Flowmaster mufflers? Crossover pipe?
could timing have anything to do with it? I've put a light on this thing, who knows where it's set at. I've not been really impressed with the carb either (it might just need a rebuild.)
Any feedback would help.
71C10SWB is offline   Reply With Quote
Old 05-15-2009, 11:55 AM   #2
ZombieWeinerDog
ZombieWeinerDog's Avatar
Re: Lot's of popping and cracking on deceleration...
It has:
i would imagine its more the glasspacks. my flowmasters crack and pop a little during deceleration, but it sounds nice. i have the same setup, original 3 speed. mine does not alot at all though
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 05-15-2009, 12:11 PM   #3
clos69
Its Topless Season!!!!
clos69's Avatar
I just put flowmasters in my blazer this past Monday and it does the same thing....
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 05-15-2009, 12:14 PM   #4
ZombieWeinerDog
i think a crossover pipe would help, there was just a thread about them
1972 longbed- 454
1967 shortbed- 355
Old 05-15-2009, 12:32 PM   #5
smoky02
Location: Sunny, Florida, some might call it South Alabama
Does it only do it while driving? Or if you rev it up does it do it on deceleration then too? If it does pop real bad, it could be one of the valves in your heads not seating. I had that problem with an 88 Chevy truck I used to drive.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 05-15-2009, 12:54 PM   #6
lilred67
lilred67's Avatar
put an h pipe in your exhaust system it will take alot of the popping out of it. a possible reason your engine is doing it alot is a lean mixture at idle. there is not much fuel in the cylinder coasting a long way causing the the popping.... might could richen your idle fuel mixture a little to help it..
lilred67 is offline   Reply With Quote
Old 05-15-2009, 02:53 PM   #7
nsuengineer06
nsuengineer06's Avatar
That's a easy one! Burnt exhaust valves. I've got a 84 1 ton w/454 that does the same thing. Your exhaust valves aren't seating all the way as stated by smoky02 above.
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 05-15-2009, 04:59 PM   #8
OhioDan
OhioDan's Avatar
Thumbs up Re: Lot's of popping and cracking on deceleration...
I always heard from my grand-dad, that it was from sucking cold air back into the muffler, allowing the unburned fuel to burn in the muffler causing the popping and cracking. Does you exhaust stop after the muffler? Might look into putting a short extension after the muffler?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-15-2009, 11:22 PM   #9
Camper Power
Camper Power's Avatar
what is your vacume advance running on, ported or manifold? cause my truck used to pop and backfire when decelerating when i ran ported vacume advance, now that its on manifold it doesnt pop at all.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 05-16-2009, 01:40 AM   #10
Willys47
Willys47's Avatar
My guess is a miss firing making it pop a good ignition system would spark up the fuel mixture in the cylinder, have it burn in the exhast and making all that noise is such a waist of good fuel.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-16-2009, 10:04 AM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
While the type of mufflers can make it more noticeable, I doubt that's the cause. I would say it's something in the engine (timing, valves) or fuel delivery (carb).
I had glasspacks on my truck for many years and never heard anything like it. Last year, with new Magnaflows, I noticed a bit of snapping & popping on slow downhills while loaded with firewood.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 05-16-2009, 03:47 PM   #12
lost wages
lost wages's Avatar
on my truck when it starts to pop and cackle it means i have loose header bolts. I have the ball and socket collectors and bolts are always falling out of them.
lost wages is offline   Reply With Quote
Old 05-16-2009, 09:09 PM   #13
WorkinLonghorn
WorkinLonghorn's Avatar
^^^ Bingo.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
