Old 03-22-2009, 12:39 PM   #1
shrunken66stroker
shrunken66stroker's Avatar
Show me your 20s!
I'm looking to put 20" rims all around and need to see some pics of how they fit. Include the width, back spacing and tire size.
shrunken66stroker is offline   Reply With Quote
Old 03-22-2009, 01:32 PM   #2
SIR
SIR
SIR's Avatar
Re: Show me your 20s!
IMHO...these trucks look awful as...."DONK"...and so do most of the others....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 03-22-2009, 02:07 PM   #3
shrunken66stroker
I didn't say, show me your 26s. Agreed about donks. I'm not lifting it up, I'm tucking them in.
Old 03-22-2009, 02:10 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Here are my 20's: 20x8.5'' 5.5'' backspace. Little tite in the rear but workable.
SIR....... this is a DONK.......20's dont even qualify
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-22-2009, 02:13 PM   #5
SIR
SIR
SIR's Avatar
...got it...point taken....
Old 03-22-2009, 02:15 PM   #6
protrash64
protrash64's Avatar
......ridiculous huh?
Old 03-22-2009, 02:24 PM   #7
fercho71
fercho71's Avatar
Godzilla, godzilla !!!!!!!!!!!!!!
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 03-22-2009, 04:04 PM   #8
shrunken66stroker
that car is redonkulous. That burb looks great protrash. That's the stance I'm looking for. Do you have any pics from the side so I can see how they tuck? Is it bagged?
Old 03-22-2009, 05:47 PM   #9
protrash64
protrash64's Avatar
Yeah its bagged, but not notched. Tires are 275/45/20....so roughly 29-30'' tall. The fronts sit on the inner fender, the rear on the frame. It wasnt my goal to be on the ground, just bagged with basic stock components.
Old 03-22-2009, 11:08 PM   #10
shrunken66stroker
Where does the tire hit on the inner fenders? On the inside of the wheel first or turning? I don't have the wheels yet but may have to do the mods before I get them. How do you think I should clearance the inner fender so it doesn't rub? I have a notch in the back so I'll sit a little lower but I'd like my truck to look like this pic at ride height.
Beautiful CarryAll BTW.
Old 03-23-2009, 12:02 AM   #11
protrash64
protrash64's Avatar
The tire is resting against the inner fender directly above the hub, where the fender rolls over to horizontal and meets the inner fenderwell. If you want lower you must remove the inner fender and trim the fender edge...then you lose the hood hinge, also. You could build a tub, which is a popular option.
Old 03-23-2009, 12:37 AM   #12
shrunken66stroker
I've seen pics of tubs I think. That's probably the way I'll go. Thanks
Old 03-23-2009, 03:53 PM   #13
shrunken66stroker
Are you the only one on this site running 20s all around protrash?
Old 03-23-2009, 07:58 PM   #14
protrash64
protrash64's Avatar
I would find it difficult to believe if I am. I have 18's on my pickup. Dinos63 runs 20's and 20/22 combos. His trucks have custom suspension, however.
Post up some 20's people!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-23-2009, 08:14 PM   #15
protrash64
protrash64's Avatar
I saw you mention rubbing here and on Dinos thread. I have no rubbing issues if you dont include the fender on the tire when its aired out. Turns are no problem ....can get a little rub when extreme turning due to my bump/steering stops removed.
Dont run tires larger than 45 series and you'll be fine. Discount tire direct has a tire size calculator you can use, FYI. Punch in #'s all you want.
Old 03-23-2009, 11:39 PM   #16
62ChevyStep
62ChevyStep's Avatar
here is mine 20x8.5 5.5BS Boyd Coddington Smoothie II's
tires are 275x20x40 front 275x20x45 rear
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 03-24-2009, 11:52 AM   #17
shrunken66stroker
Thanks 62step. I'm looking for more..... Anyone? 20s?
Old 04-12-2009, 02:36 AM   #18
shrunken66stroker
Last call for 20's all around... anyone?
Old 04-12-2009, 11:37 AM   #19
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
Here's some pics of the front end with the wheel on but I haven't put longer studs in yet so I can't put them on and let it off the jack. But I will be running the 20's all around with matching Kumho 275/45/R20's. And the truck is at stock height though I'll probably do a 2" drop down the road.
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 04-12-2009, 03:29 PM   #20
LinkbeltOE
I want to do 20's also but want the staggered look, deep in the back and shallow in the front.
LinkbeltOE is offline   Reply With Quote
Old 04-12-2009, 05:17 PM   #21
Kmart2352
Kmart2352's Avatar
Here a pic of my truck with Boss 303 Wheels. 8.5 in width and the tire is 275/45/R20.
87 2wd GMC Sierra Classic.
86 4wd GMC Sierra Classic.
95 2wd GMC Sierra.
96 2wd Chevrolet S-10.
Kmart2352 is offline   Reply With Quote
Old 05-16-2009, 02:04 PM   #22
shrunken66stroker
I'm reviving this thread because I'm about to special order some rims and I won't be able to return them once I get them. I'm ordering 20" rims that are 8 1/2" in the front and 10" wide in the back. I need to know if anyone has back space measurements so these rims will tuck in after the air is out of the bags. I'm thinking a zero offset on both front and back will work but I'm not sure. Anyone?
Old 05-16-2009, 05:05 PM   #23
64shortc10
64shortc10's Avatar
Heres mine dont know the backspace tho!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 05-16-2009, 05:15 PM   #24
shrunken66stroker
Tony from Norcal
That's what I'm looking for. Could you possibly measure for me? From the back of the mounting flange to the inside edge of the rim. Are yours 8 1/2" wide all the way around?
Old 05-16-2009, 09:01 PM   #25
jr's62
jr's62's Avatar
man i really like the way your truck sits 64shortc10.
jr's62 is offline   Reply With Quote
