Old 05-19-2009, 06:50 PM   #1
bubbletop1961
bubbletop1961's Avatar
Frame id ?
Did a search and found where to look for frame serial #'s. The fame # I found is S 35123. I found it on top of the driver frame rail. By the power steering pump and just ahead of rear cab mount. Had the same # in both spots. It is a 71/72 I believe. It has disk brakes, 1 1/4" rotors on it. 5lug wheels with a 12 bolt. coil spring rear susp.
The reason I ask is Im getting ready to order drop spindles, And the 71/72 spindle have a different part #. Want to get the right ones. Thanks
http://profile.myspace.com/index.cfm...ndid=186313550
Current project is for sale. 4" chop, channelled, lowered 5", http://67-72chevytrucks.com/vboard/s...d.php?t=347067
bubbletop1961 is offline   Reply With Quote
Old 05-19-2009, 07:08 PM   #2
john
member #16
john's Avatar
Re: Frame id ?
If it is a 71 you should have a 1 in front of the S which is for St Louis plant and the rest are sequential serial numbers. (1S35123)
john is offline   Reply With Quote
Old 05-19-2009, 07:35 PM   #3
bubbletop1961
Re: Frame id ?
I agree, but there is nothing there in either spot. Any other methods of telling, or will it make a differance with the drop spindle since it already has disk and 1 1/4 rotors.
