View Poll Results: What motor should I go with? | |||
305 remanufactured with 3 year warranty (no core charge) |
7 | 29.17% |
350 remanufactured with 3 year warranty ($500 core charge) |
14 | 58.33% |
Used 350. |
3 | 12.50% |
Voters: 24. You may not vote on this poll |
#26 | |
...just another truck junkie..
![]() Join Date: May 2009
Re: Help!!! I need your opinions.
Mike "Bear" Shea |
#27 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I let it lapse because I am completely buried with work and there is no need to try and advertise anymore.
#28 |
Can I add on a D) 383? I know it doesn't help ya, but a good solid 350 remanufacture will cost just a few hundred less than the 383?? Vortecs, etc and you'll have a 400hp monster? But as said before if the WEE-O-FIVE is OK with you, reseal it and go??
#29 | |
Still livin the "dream" in '54
The back of my truck get coated with thousands of spots of oil and I have actually been asked by a few of my customer's dealerships not to park my truck on thier lot without putting cardboard under it while it's there. I just cannot imagine that an engine that is loosing THAT much oil can be in superior shape. I was simply stating that I might be looking at a worst case senario. The hard part about a rebuild is taking the darned thing out. I have to put 1-2 quarts of oil into my truck a week, depending on how much driving I do. Oh, and the smell of the oil cooking on my pipes stinks and smokes when I sit waiting at a light. This is no small leak guys... I mean it POURS out of the front main... D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
#30 |
someday it will be done!
personally,I'd go with a reman.350 or the 383 that 70rs/ss mentioned.I had a similar issue last year with a worn out 305.I built myself a mild 350 with an rv cam,flat tops and new vortec heads.I'm very happy with it,though if I did it again,I'd find a roller block and build a 383...I'm over flat tappet engines..Oh and the machine shop that did the block/head work for me had zero interest in my 305 block as well.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#31 |
Chasin' the Dream
Reman 305 and fix your tranny. Your happy with the 305 and don't care what others think about it, and your tranny is fixed.
I'm confused why you asked after reading all the posts and rebukes to all the posts. You know thats what you want. Go on out there and get man! Grab it by the horns and satisfy yourself!
Born with a Bowtie ![]() 1971 C/10 350/350 Daily Driver/project Assumption=The mother of all ![]() Last edited by Highsteel; 05-19-2009 at 06:45 PM. Reason: speling, lol |
#32 |
resident oilfield trash
Well if you slack off on the craftsmanship maybe you would have some spare time. Your just too good and too cheap
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#33 | |
#34 |
sharp as a marble
![]() Join Date: Jan 2007
FINE 69 is spot on!! I have been down this road a time or two. IF I were you I would waste a couple hundred, and find THE RIGHT SHOP to help diagnose your troubles. If your truck runs well, then fix it! I might suggest you listen carefully on start up to see if you hear a rattle when the engine is cold. If so there might be lower end issues ( main or rod bearings ) if not put a mechanical oil pressure gauge in the engine, and start it up and look. If the pressure is right, ( both hot and cold ) reseal it, and a set of valve stem seals, and you are out some of your time, but not alot of money.
#35 | ||
My problem is not a "what should I do", it's more of an "what can my money be best spent on?". I think the best thing for me to do is; pull the motor, fix the seals and valve seals and put it back together and pray. I can concentrate on my transmission and do it right and save up for a new motor in a few more months. Quote:
![]() Figuring out where this thing is leaking should be ppprreetttyyyyy easy! ![]() D PS Thanks guys! I am reading every post and learning. I will decide soon!
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 05-19-2009 at 10:27 PM. |
#36 |
![]() ![]() Join Date: Dec 1999
Also, if your not sure where the oil is coming from check to see if its coming out of the bolt that goes to the fuel pump rod.
Seen that before.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#37 | |
![]() Lots of leaks. I think replacing the main gaskets will help. D
